any effects if i switch to 275/30/19 instead of 275/35/19?
Old Mar 21, 2009 | 08:00 PM
diablo1356's Avatar
just like the title states...is there any detrimental effect if i switch?
Old Mar 21, 2009 | 09:48 PM
g35koupe's Avatar
The diameter difference between 275/35/19 and 275/30/19 is more than 4%. Its recommended that the size variance doesn't exceed OEM by more than 3%. Your odometer will run fast, and you might run into VDC issues depending on the size of your front tires.
Old Mar 21, 2009 | 10:51 PM
Triple8Sol's Avatar
You DO NOT want 275/30. Stick to 275/35 or 285/35, as long as your rears are is between 9.5"-11" wide.
Dallsinghjr1
Sep 17, 2023 11:25 AM
KruZZe
Feb 27, 2023 05:04 PM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
vamarris
Sep 26, 2015 12:56 PM
