Brembos and 17" wheels
Old Mar 25, 2003 | 09:03 PM
skepticlion's Avatar
I would like to know if anyone has had experience fitting 17" wheels over the Brembo brake package. I need to plan for winter tires next fall and would like to find rims that fit.
Old Mar 25, 2003 | 10:25 PM
RaySur350GT's Avatar
Re: Brembos and 17" wheels
They fit, just make sure you have the right offset and you should be fine.
Old Mar 26, 2003 | 01:40 AM
G35Lin's Avatar
Multi-Spoked Mod
So are you saying that brembo brakes will fit on stock 17 inch rims? Sport packaged ones?
Old Apr 28, 2003 | 01:16 AM
Greg40MD's Avatar
Hi,
Is it possible to replace my 17 wheels and standard brakes with 18 inch wheels and Brembo brakes on my G35 coupe from the dealership? I would like to have the better brake system. Any suggestions? Thanks
Old Apr 28, 2003 | 01:44 AM
rajc007's Avatar
Replacing the brakes will be pretty expensive. I know that the StopTech 14" big brake kit runs about $4k for all 4 wheels, you'll probably pay that much at a minimum getting everything from the dealer.
Are you planning on taking your car to the track? If not I don't think you would see much of an improvement on the street by upgrading to the Brembos.
As for the 18" wheels, you can probably pick up a set of coupe wheels/tires for around $1500 secondhand. They will charge you an arm and a leg if you get them through your dealership.
CB G35 Coupe 6MT
19x8/20x10 Axis Se7en Mods (will be on soon...)
Jiggerjuice
Oct 5, 2015 02:33 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Popes
Jul 29, 2015 05:07 PM
Karnicle
Jul 23, 2015 05:08 AM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
