View Poll Results: Help me decide
18 and younger
0.77%
19 - 21
1.54%
22 - 23
2.06%
24 - 27
18
4.63%
28 - 31
1.03%
32 - 35
1.54%
36 - 40
0.26%
41 - 46
1.54%
47 - 50
0.77%
51 - 55
0.51%
56 - immortal =)
0.51%
July 17 & 18
11
2.83%
July 24 & 25
0.26%
July 31 & Aug 1
1.03%
Aug 8 & 9
0.77%
Aug 15 & 16
0%
Aug 22 & 23
0.77%
Yes, Definetly
22
5.66%
Have to see it first
57
14.65%
Maybe
1.80%
Yes, Definetly
16
4.11%
34
8.74%
Maybe
1.29%
Cancel your order with Intense and order from someone else.
0.26%
That's just the nature of ordering from Japan.
0.77%
Relax, it's only a chin spoiler. It'll arrive.
0%
Quit whining I had to wait 4 months for my G to get here.
0%
In the front
0.26%
In the rear
2.31%
I like 2005 G35 HVAC Controls
5.91%
I like 2005 Altima
3.86%
July 24th
1.03%
July 31st
3.86%
As many choices as you would like
1.03%
Overnight Is koo
0.77%
One Day is enough
1.80%
don't care, can do either
0.77%
Weekdays
0%
Saturdays
11
2.83%
Anyday
0.26%
I don't use it because I think it's a waste of money
2.06%
I don't use it because of some other reason
1.03%
I use it
37
9.51%
HKS Hipermax LS+
2.06%
Tein Flex w/o EDFC
2.57%
Voters: 389. You may not vote on this poll
You vote: HKS Hipermax LS+ or Tein Flex w/o EDFC?
Old Jun 30, 2004 | 03:52 PM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
Old Jun 30, 2004 | 05:32 PM
Gsedan35's Avatar
Re: You vote: HKS Hipermax LS+ or Tein Flex w/o EDFC?
The issue I see is that your have two polar opposites. The Tein CS is in the same market as the LS+ . The Hipermax II is more competitive to the flex. Flex use's a lot higher spring rates, does use weak rear spring rate's for G35 applications like the LS and LS+ do, and allows you to adjust ride height independent of adjusting the springs.
CS vs LS+, I have reason to think the LS+ is the more performance oriented system in terms of dampner valving, but the CS does use equal spring rates front and rear as mentioned.
HKS LS+ 504/448 vs oem= +60%/+31%
Transfers 29% roll stiffness to front
Tein CS 392/392 vs oem = +25%/+15%
Transfers 10% roll stiffness to front
HKS II 504/504 +61%front +47%rear
transfers 14% roll stiffness to the front
Now notice how much stiffer then oem the Tein flex spring rates are.
Tein Flex672/672 vs oem=+114%/+98%
Transfers +16% to front
If you order the JDM Tein flex you get these spring rates
560/560 vs oem= +78%/+64%
Transfers 14% roll stiffness to front
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Old Jun 30, 2004 | 05:56 PM
protocav's Avatar
randy,
i have the LS+, and i can tell you that they are not that soft. i run them on full soft, and they have a really sporty ride. they are stiff, but comfortable. if you dial up the stiffness, you can make them pretty uncomfortable if you want. the stiffest i ever had them at was 15 out of 30 clicks (half way for the not so math inclined folk) and that was too stiff for me...great for a track though.
if you are down in SD again, we will go for a drive...perhaps at our June 5th drive?
the flex will be a punnishing ride, especially in LA.
it is true that the LS+ transfers 29% roll stiffness to the front, but if you add a set of hotchkis sways and set the front to full stiff (63% stiffer than stock) and the rear to medium (92% stiffer than stock) you will net a neutral balance...(92% - 63% = 29% roll stiffness to the rear).
Chad
Old Jun 30, 2004 | 07:20 PM
a.k.a. RANDYS_G
Thanks for the input...so, do you like the Flex better? I'll be tracking the car.
2 G or NOT 2 G, there is no question!
Injen SES, Kinetix cats, K&N Typhoon, 19" PIAA Super Rozza's (19x9 & 19x10)
Old Jun 30, 2004 | 07:44 PM
Profile4's Avatar
i'm a noob when it comes to suspension, is it better to have more roll stiffness transferred to the front or what? what do the transfer numbers mean in terms of handling? is it an oversteer/understeer thing? thanks for the info, i'm not too far from a purchase either, and i'm trying to do all the research i can.
04 DG/G/6MT/Premium/Nav/Clear Bra
Bone Stock...to be continued...
"You kill mah brodah, now I kill you!" - some old kung-fu flick
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
