Spacers for Volk SF challenges.
Old Mar 29, 2009 | 02:31 PM
urban's Avatar
Just need some quick info to see if anyone knows the answer. Do the challenges have a space in the back of the rim to accomadate for the studs of the Kic spacers?
Thanks in advance.
Old Mar 29, 2009 | 02:52 PM
tbg35c's Avatar
I have hubcentric spacers and it fits the SF challenges no problem at all. The spacer has its own extended stud that goes to the wheels and a ring to keep the wheel locked to the spacer.
Old Mar 29, 2009 | 03:04 PM
urban's Avatar
Thanks buddy, I was just to lazy to remove mine to check the backside of the wheel out
Old Mar 30, 2009 | 05:29 AM
Triple8Sol's Avatar
Yes, they have deep pockets so you can run as small as 10mm with built-in studs.
Old Mar 30, 2009 | 01:58 PM
jdmgee35's Avatar
I think the fronts will, but the rear don't have the deep pockets. Very typical of Volks.
Old Mar 30, 2009 | 06:26 PM
Triple8Sol's Avatar
It has nothing to with being Volks. If you're running a high pad up front for caliper clearance, that means it's going to be thicker/deeper than a low pad in the rear.
Old Mar 30, 2009 | 06:39 PM
urban's Avatar
Thanks for the confirmation, I did check and they Will work for my rears which is what I was concerned about.
Old Mar 30, 2009 | 06:41 PM
Kris79's Avatar
battle froggy
most volks do
Old Mar 30, 2009 | 06:44 PM
urban's Avatar
Originally Posted by Kris79
most volks do
Hey Kris, if I add the spacers and lower the car about an inch more will this make me prone to tire rub, last thing I want to do right now is have to roll my fenders
Old Mar 30, 2009 | 06:48 PM
Kris79's Avatar
battle froggy
how big of a spacer? and what tires and sizing you using? and camber
Old Mar 30, 2009 | 07:24 PM
urban's Avatar
15mm spacers, running 275/35/19 Dunlop SP in the back and 1.9 of negative camber.
Old Mar 30, 2009 | 07:29 PM
Kris79's Avatar
battle froggy
you will rub. i am surprised your not rubbing rite now.
Old Mar 30, 2009 | 07:42 PM
urban's Avatar
You sure? According to this pic from last weeks meet, I am no where near rubbing but with spacers I probably will especially as I have a finger gap I want to get rid of also.
http://s15.photobucket.com/albums/a3...lsize=6109.jpg
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
w4kj4k
Oct 2, 2015 07:57 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
