Offsets
Old Mar 31, 2009 | 02:36 AM
JCapstick's Avatar
Offsets
I have a 2004 G35 coupe 6mt and I was thinking about putting 20 inch rims on it and I want them to be flush with the fender, not sunken in like the stock wheels are but I don't want it to be possible to hit the fender if I hit a dip. I was looking at a set that 30mm offset in the front and 35mm offset in the back.
Old Mar 31, 2009 | 03:04 AM
ShanesG's Avatar
you have to take widths into account when calculating where the wheel is gonna sit, not just an offset.
Are you willing to roll your rear fenders? I hope so, that'll give you a better chance at getting flush, you WILL NOT be flush without rolling your fenders plain and simple.
Post what widths you're looking to run and we can give you a better idea of the offsets!!!
Old Mar 31, 2009 | 12:38 PM
JCapstick's Avatar
Offsets
Thanks for the reply. The fronts are 8.5 inches wide 30mm offset as you know, rear 9.5 inches, 35mm offset. As long as the fenders still look the same and it doesn't make it a lot easier for them to be bent in, I don't mind rolling them.
Old Mar 31, 2009 | 12:42 PM
ShanesG's Avatar
then w/o running any stretch i'd say offsets around +0 for the front and about the same for the rear!
so 25/30 mm spacers all around!!!
Old Mar 31, 2009 | 03:48 PM
hargey's Avatar
hey same question i ordered a rim and tires package from rims n tires.com and they say direct fit...I ordered 20 inch MSR rims... what do u think..
Old Mar 31, 2009 | 03:52 PM
ShanesG's Avatar
any wheels with the same bolt pattern will be "Direct fit" haha
Find out the offsets/Wheel widths as well!!!
Old Mar 31, 2009 | 03:55 PM
hargey's Avatar
hey go to www.rims-n-tires.com and put in 04 g35 coupe and look at the MSR 93 B
I ordered them with perelis
Old Mar 31, 2009 | 04:02 PM
ShanesG's Avatar
8.5 +24
10 +24
15 front and 20 rear for spacers will get oyu pretty flush, will require a fender roll!!!
Old Mar 31, 2009 | 04:05 PM
hargey's Avatar
i just got my car last year.....so they will work out ok?? explain sorry for being a dumbass about this ****..
Old Mar 31, 2009 | 04:20 PM
ShanesG's Avatar
they will fit fine, they just wont be flush!!!
Old Mar 31, 2009 | 04:23 PM
hargey's Avatar
is that a big deal not flush? how do you make them flush...who will do that?? thanks man most people a jerks for guys like me haha
Old Mar 31, 2009 | 04:25 PM
ShanesG's Avatar
you'd have to run spacer to make them flush. Being flush and having good fitment is kind of a big deal though if it doesn't matter to you then you are fine without spacers they wont look to bad!!!
Old Mar 31, 2009 | 04:26 PM
nghiars's Avatar
whether its a big deal or not depends on you.. if it bothers you and you want to make the wheels flush with your fenders, get 15mm spacers up front and 20mm in the rear. To get it flush and not have your tires rub, you would need to roll your fenders. ShanesG does fender rolling so if you're in so cal.. shoot him a pm to get it done.
Old Mar 31, 2009 | 04:30 PM
hargey's Avatar
when will my tires rub...will they rub for sure?? im in ontario canada lol
is it a big job to put in spacers?? i donno
Old Mar 31, 2009 | 04:33 PM
ShanesG's Avatar
No, just bolt on, you wont run right now but if you decide to get spacers you will rub and will have to get rear fenders rolled. So it's all up to you!!!
