will going from 18's to 19's raise the actual height of my car all around?
Old Apr 4, 2009 | 06:38 PM
nyckid's Avatar
I am curous about this. Was wondering if i would get more clearance by going from 18's to 19's?
I am dropped on tein s-techs with ings+1 all around. and its close to impossible to fit the stock jack under my car to jack it up, even if i drive over some blocks of wood.
So i am wondering if i get 19's will it give me extra clearance all the way around?
Old Apr 4, 2009 | 06:42 PM
Buzz Killington's Avatar
From: Intergalactic proton powered electrical tentacled advertising droids!!!
Changing rims won't do any difference, Changing the overall diameter of the tire you mount on those rims will...
What size are the tires you already have vs the size of the tires you intend on installing on the 19's.
You can also input the data on this site for comparison.
http://www.1000rims.com/rt_specs.jsp...5&text1=&text2
Old Apr 4, 2009 | 06:55 PM
nyckid's Avatar
i believe my stock tires are 225/45R18 for the front and 245/45R18 for the rear
what would be the equivalent of that if i were to get 19's with tires? 35 front and 35 rear with 19's will be the same exact size as my 18" setup that i have now?
Old Apr 5, 2009 | 11:25 PM
JD_AND_DA_G_RIDE's Avatar
I've seen folks running (235 245/35) and (275/35 or 285/30) rear. I'm actually bumpin up to 245/45 front..one thing I definitely suggest AGAINST..is doing 285/35..it's throwin my VDC off like crazy on any little curve plus even at stock height you will need your fenders rolled (rear). 275/35 is safe..285/30 really worked for me and from time to time, I'd get a lil bit of rubbing but nothing bad..just my humble 2 cents.
Old Apr 6, 2009 | 07:02 AM
Michelin pilot sport tires, 225/45 r18 = 25.8" overall diameter, 245/45 r18 = 26.8" overall diameter... Now when shopping for new tires, just make sure the new ones are the same overall diameter as these measurements and there shouldn't be any problems...
Just go to TIRERACK.com and chose your tire sizes, pick your tire, and then go to "SPECS" to find out their overall size.
Just to do some of the work for you, tire rack lists the dunlop sp sportmaxx tire 245/35 r19 as 25.8" and the 275/40 r19 as 26.7". Don't hold it to me, but that should be in the ballpark...
Old Apr 6, 2009 | 08:36 PM
BuckeyeInMI's Avatar
I assume you have a Coupe. These diameters are pretty close, but some manufacturers will be slightly different, so check the specs before buying.
225/45-18 = 25.9" (your current F)
245/45-18 = 26.7" (your current R)
225/40-19 = 26.1" (OEM 19" F)
245/40-19 = 26.7" (OEM 19" R)
245/35-19 = 25.8" (Optional 19" F)
275/35-19 = 26.6" (Optional 19" R)
Basically, keep the fronts around 26" and the rears around 26.7".
chinee
Jun 10, 2024 07:48 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Karnicle
Jul 23, 2015 05:08 AM
