alignment really necessary on a lowered car?
on
I know my question is off topic, but I dont want to open a new thread since my question is related to this topic.
I bought a used set of rims from a member here. His car is dropped without an alignment. So the camber wear is really bad, the inside tread is gone, completely gone, I can see the steel layer of the tires (fronts only). They are now on my car, my car is running stock height (no suspension mods, completely stock). The outside tread is still in good condition (70% tread life). So is it ok to run with these front tires? Are they going to even out or they keep chewing on the bald area (inside tread)? Thanks.
And Yes, you will need to get an alignment if you want to save money on tires. My problem is a good example for you.
A good rule of thumb is that most cars can be lowered about 1.5 inches without complications. Beyond that, changes in a severely lowered car’s suspension may negatively affect ride quality, tire wear and increase the risk of "bottoming."
I dropped my G on the Pro Kit and didn't need an align kit.
on
Thanks for your quick response. I know it is not safe to have these front tires on my car, but my question is that are they going to even out? And BTW, do you know any reputable shops that sell used tires for a good deal in Socal? Thanks.
replace those tires now. even if they wear evenly, you're going to keep burning through the exposed metal tread. no amount of money is worth your safety plus you put anyone driving near you at risk.
rezendvous420
05-31-2020 01:26 PM
