Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
What tires should I put on a 10.5/19 and 11.5/19 if I'm not stretching, and if stretching I just want enough to get that round look on the tire besides the boxy look from not stretching. I'm currently looking at hankook v12 from tire seeing as I can't find any one that's selling tires for a decent price any more, please help guys ready to buy tires now and ready to put my new whrels on.
Ok so i recently purchased the penta's in 20x9 +25 and 20x10 +25.....i am currently lowered on 350z s-techs with the rear spring mount mod but i will be getting coilovers in like 2 months. i will be slammed when coilovers are on the car. i was thinking 225/35 front and 235/35 rear for both now and when i install coilovers....Oh and i will be installing spacers just haven't decided what size spacer. KNOWLEDGEABLE and HELPFUL input appreciated!
*Front and rear fenders rolled flat with slight pull in rear*
Ya found a great deal on some new 20x10.5 xxr wheels with new tire not that I went and bought the tires on purpose. More then anything I was wondering how the 20x10.5 would work in the front more then anything plus ill have to double check I'm my car isn't lower a bit already (trade for it a couple months back)
To run those tiny tires you need to run spacers.
for that front wheel (20x10.5 +35) you need a spacer to clear suspension.
Look at different wheels IMO
Tires depend on offset, only stretch if you need to.
Mild stretches on 10.5/11.5 stagger would be something like 255/35 and 275/35.
V12 are **** if you're running camber, you'll be through them in 2k miles.
What are you asking? What size tires to run or what size spacers to run?
You need to decide what final offset you want in order for me to tell you what tires to run.
You need to decide what final offset you want in order for me to tell you what tires to run.[/QUOTE]
Final offset i want is 0 or negative
Hey everyone, Im looking to get Vossen CV3's for my G35 coupe lowered on eibock springs. What offset should I get for a 20x9 and 20x10.5 I dont want any stretch on the tire. But I want to be flush. Id like to run a 285 tire in the rear and a 265 up front. What do you guys recommend?
Ok so then I guess ill get the wheels and sale the new 245/30/20 all around. What tires would you recommend for me to get. Like the height on the tires but could do with out the stretch but don want to complete engulf the lip with the tire but do want something that would protect them from potholes
Aim for a +10ish front and rear.
Ideal tire size is 275/30/20.
Just picked up some 18" 350z Anniversary wheels to replace my stockers as a winter set up. I believe they are 8" 30+F and 8.5" 33+R with 225/45 on the front and 245/45 on the rear. I'm not lowered on anything yet but I plan on getting some Eibach Sportlines to use forma while or maybe just go straight to BC coilovers. Either way I'm abt to buy spacers for a flush look and I was thinking 25mm fronts and 32mm rears. My fenders are already rolled so my question is will these spacers work once I drop the car 2-2.5 inches without running a lot of negative camber or pulling my fenders? I prefer the meaty tire look with no wheel gap. Or will I need smaller spacers?
In short, yea those spacers can work.
Answer is.... Nothing. 8 and 8.5 are too small to stretch on. You need a 205 or smaller to even start pulling bead on an 8.5.
Thanks for clearing that up- should've thought about that one.
Another q, not wheel related(but I know ur not into pm), did you use plug play projector kit for your lights in the high beam? If so which one, morimoto?
Thanks
Thanks
I found some XXR 006, black with Copper lips, I think they would great on my OB G35 coupe. I do not have any other mods besides sway bars, it is the 06 model with sport suspension. The wheels are 20" x 10" with a +35 offset. Will those fit or am i going to need spacers, if so, what size spacers? Or should I find a different rim. Also, they have 20" x 8.5" +35, not sure if I want to stagger them or go with 10" all the way around, any help will help......they go off sale today.
[/IMG]
