Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Jul 11, 2013 | 06:08 PM
  #5866
Tukeeg35's Avatar
Hey guys,
I got a line on a set of Forgestar F14's size's 19x8.5 + 25 fronts and 19x9.5 + 35 rears, how close to flush do you guys think these would be?
Im also considering a set of Enkei RPF1's in 19x8.5 and 19x9.5, any insight on offsets would help a tonnn
Im a total newb when it comes to offsets so any help would be appreciated!
Thanks!
Old Jul 14, 2013 | 12:10 PM
  #5867
ItsA..Gthing's Avatar
Is it mandatory to roll rears on 19x10.5 et 22....... 275/35/19 1 inch drop ...3 degrees of camber
(03 coupe g35)...Pics of 10.5 et 22 rear specs appreciated
Old Jul 14, 2013 | 01:57 PM
  #5868
OBsessed's Avatar
Originally Posted by Tukeeg35
Hey guys,
Thanks!
The 8.5/9.5 with those offsets will be extremely weak on a Coupe. If you've got a sedan you'll be good (I think, but don't quote me on that, get a sedan guy to verify). It looks like from your sig you're a Coupe guy though. 8.5 is very weak for the front end of our cars when it comes to aftermarket wheels. The most common is the 9.5/10.5 with offsets ranging from +5 to +20 (stance/hellaflush crowd not included for obvious reasons). I recently picked up a set of enkei rpf1s in 18x9.5+15 and 10.5+15. I've got some fender work done from a previous setup but they're a good bet on stock fenders as well. Do you have any plans to lower the car? Your ride height plays a huge part in what you can or can't fit.
Old Jul 14, 2013 | 01:58 PM
  #5869
OBsessed's Avatar
You should plan to roll them, it's just a good idea to have done since at some point down the road you're going to make a change that will require it. It'd be pretty close as is, I'd just get it done for ease of use.
Old Jul 14, 2013 | 03:53 PM
  #5870
Was wondering how many more MM closer to the fender the 10.5 et 22 would be, compared to the 9.5 et 15 im running now...If you now Obsessed,i would appreciate it...Just don't wanna roll incase I go back to 19 Rays in future...Tnx
Old Jul 14, 2013 | 10:03 PM
  #5871
OBsessed's Avatar
Rolling will have no bearing on going back to Rays later on. All it does is smooth out the inner portion of the fender lip. There's no visible change on the outside at all if done well.
10.5+22 v 9.5+15
Should be about a 6mm difference in poke on the wheels, tire size may alter that. Use www.willtheyfit.com for a better idea.
Old Jul 15, 2013 | 01:31 PM
  #5872
Tukeeg35's Avatar
OBsessed, thanks for all your input man!
Ive decided to go with a square (18x10.5 +15) set of Enkei RPF1's, I'm currently lowered on an Eibach Pro Kit, do you have any suggestions on tire sizes? I'm going to have my rear fenders rolled for sure.
Old Jul 15, 2013 | 05:37 PM
  #5873
InfinitGman's Avatar
Spacer question:
I want to improve my offsets in the rear on my coupe and my buddy has some 10mm "slip-ons" which he ran on his G that he'll give to me. Can I run those on stock studs and be fine?
Thanks for your help! Hope you all have been well!
Old Jul 15, 2013 | 05:49 PM
  #5874
OBsessed's Avatar
I'm running 285/35/19 rear and 255/40/19 front but if you get lower than around a 26" rear fender height / 25.5" front fender height you're going to want to roll and slightly pull/flare the fenders to fit them. I already had the work done because I was stupid low and running aggressive offsets for a while. You should be fine stepping those down a bit, a 275/35 rear and 245/40 front (damn near ideal, just about half a percent height difference and shouldn't rub with just a roll) or 275/30 rear with 245/45 front (slight difference of about 1% in height between the two, but still shouldn't rub, just won't be quite as meaty).
Originally Posted by InfinitGman
Spacer question:
Stock studs should not be used with slip on spacers. If you shop around at reputable places like Z1 they'll include extended studs even for their 5mm slip on spacers, the 10mm is definitely a no-go. Having said that though, if you call them up and ask they'll most likely sell you just the extended studs. If you're using stock wheels though, 10mm isn't going to put much of a dent in the sunken look you've currently got. Many times guys will opt for 25mm or larger studded spacers to flush them out.
Old Jul 15, 2013 | 05:51 PM
  #5875
OBsessed's Avatar
Tukeeg35 - Also when choosing your tire sizes (because you can certainly go narrower than I listed if you'd like and it won't hurt you) make sure the front and rear are within 3% of each other for height. The VDC will start kicking in if it sees one rolling too fast or slow compared to another, so try to stay well under that 3% difference. That's why I mentioned what the difference was in my suggestions to you.
www.willtheyfit.com is a great calculator with a visual interpretation of how they'll look that I find quite helpful.
Old Jul 15, 2013 | 07:50 PM
  #5876
Nope no stock wheels, my friend was telling me that it can me done without studs and I was just wanting to get a second opinion. I was hoping to actually do something to my car that wasn't going to cost me money haha
Can't ever cut corners though and it's better to be safe than sorry.
Thanks for the help!
Old Jul 16, 2013 | 12:13 AM
  #5877
If you ran 10mm without extended studs,you would hardly have any thread to secure your lugs safely...Some friend..lol
Old Jul 16, 2013 | 12:16 AM
  #5878
Obsessed,ordering new wheels manana...19x9.5 et15 and 19x10.5 et 22...might go get a moderate roll on the rears tomorrow....The 275/35 rear should have a mild stretch on the 10.5..
Old Jul 16, 2013 | 09:18 AM
  #5879
OBsessed's Avatar
I don't think a 275/35 would be considered stretched on a 10.5. It'll fit correctly. A 225 would be considered stretched
Just buy my KFs and go aggressive for a while
In all seriousness though, that will look good. Which wheels are you going with?
Old Jul 16, 2013 | 11:07 AM
  #5880
TGMcCoy's Avatar
275 would be extremely mild stretch...
The dude that test fit your KF on his Z backed out?
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
