Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
#5116
Thanks Blain, would you suggest i have the other lips stripped to match or maybe have them all chromed? What is the typical cost for a new lip? One last question, do i need a special socket to take the hardware off or is it a standard star bit?
btw, i am still confused on lip measurement but whatever
#5117
Up to you, the raw polished is usually brighter than the anodized finish.
Between 200-250 a lip. Depending on size.
They're a 12 point socket, I can't recall the size off the top of my head, but avoid torquing wheels or removing hardware by twisting the "fancy" side of the bolt. Loosen an tighten the hardware buy the nut side inside the barrel.
As for the measurements, just gotta know where the bead is!
This is a 5" lip, from BEAD to FLANGE it's 5"
This is 5.5" lip
This is 5.5" lip
#5118
how durable is the raw polished? my tires are still on the wheels so i don't know where the bead starts unfortunately. i guess maybe wheel flip will have a database or something and can punch in my specs and know without measuring. that's not too bad on the price actually, i will probably do that.
now i am not sure if i want to go .5" or 1" more lip in the front. If i go 1 inch i will need to go .5" more in the rear as well
As for tires, if i got to a 10 inch wide in the front, i will probably need a 235/35 to match the stretch I have now.
#5120
How durable? You should repolish them by hand every once in a while, but you can get away with spot cleaning them with some type of quick detailer between washes. Polishing is such a pain though. Hand cramps! Haha.
The nice thing about having them polished though is that if you ever notice tiny little scratches in the metal you can just polish it down until it looks like a mirror.
#5121
#5122
#5123
I currently have 19x9.5 +22 all around and am switching to 19x8.5+25 and 19x9.5+30. How big of a spacer will I need for the 8.5 to fit like my current setup?
Also, I will be switching setups again hopefully soon and will be putting a 10.5 +24 in the rear. How big of a difference is that from my 9.5 +22? Any idea how much added negative camber will make this fit? I'm currently -2? Thanks for the help. Hope these questions make sense.
#5124
#5125
#5127
#5128
8.5" + 10 is equal to 9.5 +22
10.5 +24 is 14mm more aggressive than 9.5 +22.
Need more info to tell you if you need to add camber. (tire size, coupe or sedan, vehicle height)
#5129
Going to need stretch like TGM said, also a lot of camber and some fender work. Fenders absolutely need to be rolled flat and you'll want some pull in the rear so you don't have to go super negative on the camber. Below is 19x11.5+2 with 255/35/19 (should have gone 265/30) at -5.5 degrees camber. Fenders are rolled and have a minor pull and still pokes. If you want to stick with the tire sizes you listed you're going to want to look into some form of widebody.
#5130
You could start there since you've already got them, but it's going to take a good bit of camber (more than I'm running) and a bunch of fender work, but... Honestly, and I don't mean this to sound rude, but this might not have been the ideal first set of aggressive wheels for you. I only say that because it's going to take a good bit of work to get them right. Fitment like that done isn't done over night, it's usually something you work up to. Start with the fenders, get them as flat and pulled as you can and see then how much clearance you have for what size tires. Starting with the tires and then doing the work to make them fit is backwards.
