Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
#5163
what wheels? no way to tell what the disks mean.
But you already know the disk, just look at the companies website and found out yourself...
#5165
#5166
Received 1,939 Likes
on
need tire experts.
need to replace my rear tires soon. currently have 295/35/18 and they rubbed the fenders at first until the rubber sidewall got worn down. it is a nitto invo on the driver side, and a toyo proxes t1r on the passenger side.
i'm looking to replace the with hankook ventus v12. but don't know if i should go with a 285/35 or stick with 295/35.
i don't want to go with a 295/35 and find out that the hankooks run fatter than the nitto or toyo, since i'll rub like a **** again. so unless someone can confirm that hankooks run skinny, i'll be getting one size down to 285/35 to play it safe.
#5169
need tire experts.
Invos run large IIRC from when I had them and Toyos are basically bang on true fitment. Hankook is said to be true fitment, but I find that depends on the tire size with those wheels (much like the Falken sizing)
If you were running on both sides then going with the 285 is going to be your safe bet, but if you were only rubbing on the nitto side then the 295 hankooks SHOULD clear the fenders.
Also, these are the 18s aren't they?
Yea 8mm spacer IIRC should make them clear with the T1S because of the mostly straight spokes. GL!
#5170
#5171
#5172
Please help with wheel and tire question.
Hello, I have a 04 g35 coupe I finally wanted to get new rims and tires but I have many questions. I have the car lowered on tanabe springs and I'm getting the fenders rolled just in case. The wheel size i was looking at are 20x10 +15 in front and 20x11 +15 in back. I have a front and rear camber kit also installed I would say my car dropped 1.5".
#1. Are those rims going to fit my car without anymore extra work?
#2. What size tires should I get?
#3. Why are people recommending r30 in front and r35 in the back and doesn't that effect the total diameter of stock total diameter?
Thanks to all that help
#5173
Any pics of a 245/35/20 stretched on a 11.5 inch rim?
Will the tire fall off when I'm driving? Putting my old tires on new sized rims plenty of tread left, running falkens on them curreny. There was a thread with some dude asking about the same setup but the pics aren't linking properly.
1) You'll need the rear fenders rolled most definitely.
2) 245/35 and 275/35. 255/35 up front would also work.
3) Because those people are dumb and shouldn't be offering advice on staggered tires when they don't know what they're talking about!
#5174
Thanks I have been trying to read as much as I could b4 asking but i never found out what I wanted and sometimes you don't know who to believe.
Can i go for a more aggressive offset in the front and rear and why are there a lot of people running 30s with the 20" wheels?
I thought 35s were for 19"s, I'm new at this stuff so sorry I'm just asking questions not questioning your answers.
Thanks
Thanks
#5175
Thanks
Thanks
You often run 30 profile tires on 20s with these car to keep the over all diameter close to or smaller than that of the OEM size.
The profile being 30 or 35 is not relevant to the diamater of the wheel. You can run 25 profile if it fits your needs.
