Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Nov 7, 2012 | 05:51 PM
  #4501
Polishthrust's Avatar
Originally Posted by 05coupeDG
http://varrstoen.com/news/es-1-1-2-1...nd-polish-lip/ found the offsets, can anyone guess these tire sizes?
Thats yusoslo's car. His tires are 245/35 front and 255/35 rear.
Thread: https://g35driver.com/forums/picture...ld-thread.html
Old Nov 7, 2012 | 06:10 PM
  #4502
ohfive's Avatar
Thanks a million polish!!!
Old Nov 8, 2012 | 10:48 AM
  #4503
05 sedan's Avatar
I want my wheels to fit a little more flush they are 19x8.5 +34 and 19x9.5 +36 what spacer size would be the best
Old Nov 9, 2012 | 11:20 AM
  #4504
4DGS's Avatar
I will assume it's a sedan from your name...
What size tires are you running and how low is the car?
Old Nov 9, 2012 | 11:38 AM
  #4505
Drew113's Avatar
Ban Hammer Expert
Blain with my new setup, 19x10 19x11 +0 all w/ 235/35 255/35 what camber can I get away with at my my height ...looking for the minimum amount of camber basically
Old Nov 9, 2012 | 12:19 PM
  #4506
4DGS's Avatar
Basically just adjust accordingly there is a few variables there that I can't calculate for.
How much space do you have fender to tire? Remember every degree of camber is 5mm in offset. So if you have 12mm of space, you can reduce camber by roughly 2.5 degrees
My Z has pretty much no camber, same tire sizes on 9.5/10.5 and specs are 6mm less in the front and 3mm less in the rear.
Old Nov 9, 2012 | 12:22 PM
  #4507
Drew113's Avatar
Ban Hammer Expert
I've got like just under an inch or an inch gap all around
Old Nov 9, 2012 | 12:50 PM
  #4508
4DGS's Avatar
Can probably straighten the wheels lol
Whats your camber at?
Old Nov 9, 2012 | 01:02 PM
  #4509
Drew113's Avatar
Ban Hammer Expert
wheels are at OEM spec right now....almost zero'd in the front and like -.5 in the rear....front are the main thing i need to adjust....only rubbing tire on the same spots i was with my old setup but wanna perfect it...i'm poking tire in the front right now
Old Nov 9, 2012 | 04:06 PM
  #4510
05 sedan's Avatar
i am running 225/35/19 and 245/35/19 how low my rear tire tucks a little and front around the fender line
Old Nov 9, 2012 | 07:56 PM
  #4511
4DGS's Avatar
^ assuming your camber hasn't been fully corrected a 10mm should fit in the rear and the front should be able to handle between 15 and 20.
Old Nov 10, 2012 | 07:30 AM
  #4512
05 sedan's Avatar
^ my camber has not been correct where should it be if i am running 10 in the back abd 15 up front?
Old Nov 10, 2012 | 03:53 PM
  #4513
4DGS's Avatar
You'll probably need the camber to fit them.
If you correct the camber you probably won't need rear spacers. The front will probably still have some room.
Old Nov 11, 2012 | 11:37 AM
  #4514
03GT35R's Avatar
Will this Offset fit Sedan???
i am looking at Vertini Drift wheel, they said they only make it for the coupe offset which is the following. I need to know if this would fit on my 03 Sedan. Current suspension is oe sport struts/shocks with Tein S tech springs. i just want to make sure that if i order and install these that they will fit inside the fender wells and not stick outside the fender wells....
19x9 front +20
19x10.5 rear + 25
prefer to run
245/35 or 255/35 front
275/35 or 285/35 rear
maybe even a 295/30 if can make it work...
thanks in advance!
Old Nov 11, 2012 | 02:10 PM
  #4515
4DGS's Avatar
19x9 front +20
19x10.5 rear + 25
prefer to run
thanks in advance!
Definitely not with those tires sizes.
You're going to need about -4 degrees of camber out back and you'll need to run at least 245/35 on the rear. You'll also need to roll your fenders totally flat.
The fronts will fit, but you'll want a stretched tire to match the rear.
You don't easily fit 295s on a sedan, especially not on your first crack at wheels.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
