Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Dec 30, 2012 | 02:00 PM
  #4876
4DGS's Avatar
255/35 /19 for tires. Spacers are really up to you, you will fit the 0s in the back no problem might want like 5mm but that's your call. May also want a small spacer up front depending on the ride height.
If you want to ride lower, run 265/30s
I personally don't like 20s much on the G, but that's just me. However if you're going to do 20s, you should make sure they have step lips! It makes the faces look the "right" size.
Old Dec 30, 2012 | 07:41 PM
  #4877
Airic214's Avatar
rims
hey guys i just got 19in rays and here is my set up
255 /40/19-rear
245 /40/19-front
i want to know if this setup is ok becuz i will be getting new tires soon. and i want to know will this wear out or put strain on my car etc.
i drive an 04 g35 sedan
Old Dec 31, 2012 | 02:31 AM
  #4878
4DGS's Avatar
Will not add strain or result in any additional wear but they're really the wrong sizes for the vehicle.
Old Dec 31, 2012 | 03:05 AM
  #4879
Airic214's Avatar
whats the right size ?
Old Dec 31, 2012 | 03:10 AM
  #4880
4DGS's Avatar
225/40 and 245/40
Old Dec 31, 2012 | 03:14 AM
  #4881
Airic214's Avatar
willl i rub with that set up?
Old Dec 31, 2012 | 03:25 AM
  #4882
4DGS's Avatar
It's smaller than the current set up.
Old Dec 31, 2012 | 11:48 AM
  #4883
Drew113's Avatar
Ban Hammer Expert
Hahaha some people just make me laugh sometimes...
Old Dec 31, 2012 | 05:01 PM
  #4884
Plur's Avatar
What spacers would you add to this setup? 19X9.5+22 225/35 19X11 +15 245/35
I'm at an 2" drop all around with -3F/-4R w/rears rolled. I was leaning towards 25mmF & 20mmR
Whatcha think? Really want -7 all around...
Old Dec 31, 2012 | 05:04 PM
  #4885
Drew113's Avatar
Ban Hammer Expert
^on a coupe??
Old Dec 31, 2012 | 05:16 PM
  #4886
Plur's Avatar
Yeah my fault^
Old Dec 31, 2012 | 05:27 PM
  #4887
Drew113's Avatar
Ban Hammer Expert
Alright...and is there a reason you WANT -7 degrees of camber
Also what setup are you running now that you have -3/-4 degrees...becuz if its the one in your comment that is an unnecessary amount of camber and stretch actually becuz you could run full size tires on that setup and still be fine and be close to stock camber
Old Dec 31, 2012 | 05:31 PM
  #4888
Plur's Avatar
No I meant -7 offsets. I'm running camber atm cause I like the look haha
Old Dec 31, 2012 | 05:34 PM
  #4889
Drew113's Avatar
Ban Hammer Expert
Oh okay.....well going for a certain offset doesn't always help becuz it changes with the widths of the wheels so a 11 wide with -7 is different from a 10.5 wide with -7...do you want both your 9.5 and 11 to be exactly -7??....
Old Dec 31, 2012 | 05:36 PM
  #4890
Drew113's Avatar
Ban Hammer Expert
If so to get what YOU want you'd need a 22mm out back and a 29mm up front
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
