Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
11 +5 is equal to 10.5 -1
My Z runs 9.5 +2 10.5 -3 with 235/35 and 255/35 no rubbing what so ever and camber is next to straight, maybe -2 front and rear.
And it's not hella slammed but it's not high in any sense, it tucks tire all around.
Wow nice Z.. didn't know you had one. Actually when I think about it -10 aint that bad. Check this out. I like the poke on his car but hes definitely lower than me. Does the height really affect the poke etc. or is it all offsets and camber?
http://vipdout.com/aint-nothing-but-a-g-thang.html
If you can't slam it out because of the Kuruma, then go 20s!
This is supposedly 225/35 on 10.5 but I dunno, doesn't look stretched enough IMO.
Nexens which run slightly larger than NS2s.
Bigger lips huh?
I think wheelflip is having a lip sale/ they quoted me 19" steps around $180-200 if I remember right... Not sure about work lips. Reverse would be cheaper I'm sure
Just make 21s foo
G35 Coupe Wheels
I recently (2 weeks ago) bought a 2006 OB G35 coupe 6mt. It is my first manual trans car and I absolutely love it! I am still pretty terrible at shifting smoothly, and seem to grind 5th gear even when the clutch is all the way depressed for some reason ... but the car is a huge success. I've wanted a G coupe for years and my dream came true. However, the previous owner chose to basically fit 16inch wheels and SUV tires all around and they are TERRIBLE. I feel the gas mileage dropping to absolute zero and the handling is abominable. Since I'm so new to this car, I was wondering if any of you who are educated about wheels/tires for the G could enlighten me. I plan on getting new suspension / lowering the car 1 - 1.5 inches in the future so please keep that in mind. Not asking you to do my homework for me, just asking for any experts out! Thanks guys
Need help with tire specs!
Hi guys,
I have done a bit of research, maybe about an hour or so and haven't found the answer I am looking for. I am in need of tires asap. Long story short I need to get new tires because one popped and I need new rears and was wondering if you guys can help me out to determine if my setup will fit. I am really concerned about the rears.
Specs:
Fronts: 19x9.5 +12 offset, 19x245x35 tires
Rears: 19x10.5 +12 offset 19x275x30 tires
Dropped ~1" all around on tein s-tech springs
Stock fenders
Stock camber
Let me know what you guys think,
Thanks
Specs:
Stock fenders
Stock camber
Thanks
