Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
#5432
Hey guys,
I have an 06 G35 coupe and lowered by about 1 inch to 1.5 inch. I prefer not to roll fenders.
Will I rub fenders if i run 255/35/19 in front on 19x8.5 +23, and 275/35/19 in rear on 19x9.5 +24?
i'm mainly just concerned about the tire width in front. Thanks.
#5433
#5434
#5435
Hey,
Just have a quick question because I'm picking up some mint oem coupe rays for my 03 g sedan, and the seller is going to also throw in 2 brand new tires on the rear wheels that are 255/40/19. My sedan is stock (atleast i think so, just bought it as is). Question is, would I have a problem using these tires or should I just tell him to keep the tires and ill get whatever you guys advise?
#5436
I need some help picking out some new tires this year. Right now I'm running Nankang NS2's. 225/35/20 on 8.5" in front and 255/30/20 on 10" rear (should these be 255/35/20?).
These tires are cheap but have performed pretty solid for me... only thing I really don't like about them is they are kind of loud. I would like to run some nicer tires though. I don't drive in the winter but it can rain quite a bit here so I am looking for a solid tire for that.
I am considering the Hankook Ventus V12's. Opinions? If I run 225/255 will these tires fit about the same as the Nankangs?
#5437
Hey,
#5438
#5440
OEM 19's
Hey guys,
I have a 2005 coupe with the stock sport suspension and OEM 19's. I'm currently running 15mm spacers in the front and 20mm spacers in the rear, and plan on going with 245/35/19 tires in the front (225/40/19 is stock) and 265/35/19 in the rear (245/40/19 is stock).
Given the spacer and tire width combination, will I have any rubbing issues when going over bumps?
Thanks a lot!! This thread is very helpful
#5441
Hey guys, I'm new to this forum and a noob to this whole offset thing. I tried doing some research but I couldn't really figure it out.
I'm trying to invest in these Works XD9 and I'm looking at 18x9 F and 18x10 R.
I don't plan to drop, so what offsets should I be using so it would sit how my 17's stock sit?
#5443
I have Hankook tires. I was just checking my tire's tread out recently. I notcied my rear right tire's tread is completely flat on the insides of the tire. All the other three tires are fine. What can cause this? I did alignment few months ago. Should i need to rotate my tires. (I wish we could rotate tires front to back than just side to side since they are one directional.) Should i rotate and balance or just rotate? How much typically rotating on a 2005 G35 Coupe cost?
#5444
#5445
Hey i'm new here and don't know to much about cars.. just have a question for you guys..I have an 03 g35 sedan..Bought some rims that are 20" 114.3 with a 34 offset (previously on a 04 maxima no issues). My car has the same bolt pattern but the offset range is 35-45..just wondering if they will fit fine or if I will need something to make it work? thanks
