Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Old Feb 24, 2010 | 11:15 PM
  #616
NFSP G35's Avatar
? = 2B || !2B
^Sedan?
  #617
4DGS's Avatar
They will fit, but they aren't ideal for that width of wheel. I'd go 235/45 as that's OEM sizing.
Old Feb 24, 2010 | 11:32 PM
  #618
opanick's Avatar
Yea its for a '05 sedan, I thought oem was 215/55 for my sedan???
I'm just asking b/c I need new tires soon and I could get these for free......
Old Feb 24, 2010 | 11:35 PM
  #619
opanick's Avatar
Old Feb 24, 2010 | 11:45 PM
  #620
4DGS's Avatar
my bad, I was actually off on the ratio too, it's 225/50
You could run them, they'll just look a little bulgy.
Old Feb 26, 2010 | 07:18 PM
  #621
valetkyle's Avatar
19x9.5 +29
19x10.5 +25
Will this setup give me a somewhat flush look without being too aggressive for daily driving? I don't want to be throwing rocks down the side of the car. Also I'm lowered on H&R sport springs so what tire size would be best and most affordable? I would rather not pick an oddball size just to get a slightly wider setup.
Old Feb 26, 2010 | 10:15 PM
  #622
Bnag0's Avatar
This has probably been brought up already... I am interested in buying 20x9Front and 20x10Rear for a 03 coupe and also plan to lower it a bit (enough for a daily driver) is there any issues i should know of when lower a coupe with 20" wheels?
Old Mar 1, 2010 | 12:17 AM
  #623
TastefullyDone's Avatar
Is there any real difference between running a +4 all around setup vs. a +0 all around setup vs. -4 all around or same camber and stretching magic needed with some pulling and rolling for all three setups to work? I have bbk (brembo) which limits my lippage even with more aggressive offsets cuz of R-disc requirement, so just wondering which gives the looks of a deeper lip, step vs. flat (full reverse)? Thank you gentlemen for all your help.
Old Mar 1, 2010 | 11:20 AM
  #624
LightsOut's Avatar
SIETESG
Originally Posted by valetkyle
19x9.5 +29
19x10.5 +25
popular tire size is F245/35 R275/35 or R285/35
sizes you choose should give you a semi flush look but not aggressive. It will kind of look as if the dealer put on a wheel package and placed the car in the show room floor. (example)
Old Mar 1, 2010 | 03:15 PM
  #625
Gtz1stballer92's Avatar
i replaced a flat tire with my spare and all the psi are at 36 but the low tire pressure sign on the dash wont come off
does anyone know y
Old Mar 1, 2010 | 03:21 PM
  #626
OCG35's Avatar
either bad sensor or bad sending unit...
did you drive on the flat? That could possibly damage the sensor...
Old Mar 1, 2010 | 03:22 PM
  #627
after it went flat i pulled into the gas station thats it
Old Mar 1, 2010 | 03:24 PM
  #628
OCG35's Avatar
might want to have dealer check sensor and sending unit...
Old Mar 1, 2010 | 04:18 PM
  #629
LightsOut's Avatar
SIETESG
does anyone know y
in the manual it shows you how to reset them. Think you had to drive like 30mph for like 10 seconds or something.
Old Mar 1, 2010 | 04:47 PM
  #630
OCG35's Avatar
are you sure?...
http://www.infiniti-techinfo.com/deptog.aspx?dept_id=56
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
