Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
#6290
I drove ttrank's car solo
Received 1,487 Likes
on
#6291
Hey guys, I have a quick question.
I have a 2008 g35x sedan AWD and am looking to get new wheels. I am interested in possibly putting some wheels from a coupe onto my car and know that I should get a full set of either front or rear wheels instead of having them staggered. I guess my question is which would be the better fit for placing all around on my car, 19x8, 19x8.5 or 19x9?
#6293
Received 1,939 Likes
on
#6294
spacers fitment...
I've searched and searched and searched....Ok so I just got some ichiba v1 12mm spacers for my rear and I went to install them only to find that when i took the rotor off to pound out the studs I grabbed a new stud to match it up and I know it's gonna be longer than the stock studs but it was WAY too long so i was unable to squeeze it behind the hub to install them. The only other way I can see them getting installed is to have a shop remove the entire hub to set them in. I was really trying to do this myself to save the time/money/hassle...if there's any other tricks to get these bad boys in please let me know thanks!
#6295
on
#6299
Hello Fellas. I had question about getting new rims. I am planning on getting rims with these specs.
Bolt Pattern: 5x114.3
Off Set: +32mm
I want that size all around so I can rotate them. I'm a college student and want to maximize my tires. My questions are
1) will 245/40/19 work fine all around with no rubbing, I have G eibach sportlines.
2) do I need to install TPMS sensors, if not, will this make anything light up on my cluster?
3) also to get a flush look, what size spacers would you recommend without having to roll my fenders.
Thank you guys so very much!!
04 5at coupe
Off Set: +32mm
04 5at coupe
