Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
  #7036
Old 05-23-2014, 02:46 PM
Urbanengineer's Avatar
Received 1,031 Likes on 948 Posts
Originally Posted by mliu66
Hi, guys I am having 04 sedan with stock 17x7 +45mm offset rim and 225/55/R17 tire, front and rear Now I want to switch to 19' rims and I have two options: 1. stock 19' rims of a coupe: Front: 19x8 +30mm offset Rear: 19x8.5" +33mm offset, tires are 225\40Z\R19, 245\40Z\R19 2. aftermarket 19' rims: 19x9.5 with a +35 offset, tires are 245/35/R19, 235/30/R19 Two questions I have: 1. I did some research but seems no definite answer if it is safe to switch to a rim with different offset. Can I use these rims? 2. I checked the tire size and diameter should be fine, but not sure about the clearance to the suspension. Should I roll fenders and/or add spacer? Need to make a decision today or tomorrow. Thanks a million!
Could you get bigger tires in the rear (245/40 or 255/35)? Measure where your current wheels are in terms of the fender line, -10 offset will move the wheel barrel out 1 cm and a 9.5 adds 0.5" on both sides of the barrel. Not that big of a jump.
Most guys running stock rays (+35, 8.5") have no issue at all on the sedans.
  #7037
Old 05-23-2014, 03:08 PM
mliu66's Avatar
Thanks for response.
Yes I am thinking of thicker tire but I checked the inner side of the tire and I felt the clearance to the suspension is kinda close. Moving to a smaller offset will get them even closer right?
Or should I add some spacer for safety?
  #7038
Old 05-23-2014, 03:34 PM
ILCruisin2006's Avatar
Can I run 255/45/17 in the rear on my OEM 17s?
  #7039
Old 05-23-2014, 03:49 PM
Edit: Deleted
  #7040
Old 05-23-2014, 04:05 PM
GNation13's Avatar
Location: origninally fromMilwaukee WI but currently living in SoCal
Hey guys just a question on rims im looking at for a coupe. Im looking at some 18x8F and 18x9.5R with both a 45mm offset. Do you think wheel spacers are needed to get more flush? How much space? 25mm? Any answers would help.
Thank you!t
  #7041
Old 05-27-2014, 04:37 PM
Bump for my tire question please.
  #7042
Old 05-29-2014, 01:23 PM
garfield's Avatar
Hello. Does anyone know what kind of wheels these are?
Thanks in advance.
  #7043
Old 05-29-2014, 02:50 PM
Drew113's Avatar
Ban Hammer Expert
Those are Lusso Forged wheels^
The following 2 users liked this post by Drew113:
garfield (05-29-2014), Urbanengineer (05-29-2014)
  #7044
Old 05-29-2014, 02:51 PM
Drew113's Avatar
Ban Hammer Expert
Thank you!t
Honestly you are not even going to get close to flush with those specs man...even if you use a 30mm spacer front and rear its still gonna be sunken in
  #7045
Old 05-29-2014, 04:52 PM
Justin Torres's Avatar
Need Tires!!!!
Im looking to buy a set of tires for my new rims, the rims are 18x9.5 +20mm all the way around. I don't want to role the fenders and my main concern is rubbing.
OEM Size is
225/50/17
235/50/17
I was thinking of going with a
255/40/18 for the Front (0.67% from OEM)
275/40/18 for the Rear (1.56 % from OEM)
Based on the tire size calculator both sizes are within the 3% limit of the OEM, Do you guys think ill have a problem putting the 255s on or should I go with a 245/40/18 (-0.55% from OEM) for the front
BTW suspension and Camber is stock
  #7046
Old 05-29-2014, 06:22 PM
Also do you think the rim width and offset is fine for our cars
  #7047
Old 05-29-2014, 11:22 PM
AJ/g35s's Avatar
Originally Posted by Justin Torres
Im looking to buy a set of tires for my new rims, the rims are 18x9.5 +20mm all the way around. I don't want to role the fenders and my main concern is rubbing. OEM Size is 225/50/17 235/50/17 I was thinking of going with a 255/40/18 for the Front (0.67% from OEM) 275/40/18 for the Rear (1.56 % from OEM) Based on the tire size calculator both sizes are within the 3% limit of the OEM, Do you guys think ill have a problem putting the 255s on or should I go with a 245/40/18 (-0.55% from OEM) for the front BTW suspension and Camber is stock
I had mind 255/40/18 rear No problem at all
  #7048
Old 06-01-2014, 06:40 PM
DRicanG35's Avatar
19×8 wheels 36mm offset.
Ok I need some help and I have searched and couldn't find any answers specific to my question. I have an 04 sedan 6mt so sport package and I know someone selling some nice 19×8 TSW wheels with a 36mm offset. I am on stock springs and shocks (sport package of course.) Would I be able to run this wheel size and width with that offset without having to make any modifications or will I need spacers or rolling of my fenders. I appreciate any help with this. I'm getting a killer deal on the wheels.
  #7049
Old 06-05-2014, 09:00 PM
famosobr's Avatar
06 g35 dropped on eibach springs planning on getting groundforce gf06 19x9.5 +15 front and 19x10.5 +15 rear wrapped in 245/40/19, question is will i need a roll or should i be fine ?
  #7050
Old 06-05-2014, 09:48 PM
ScraggleRock's Avatar
Just roll em. Its easy.
Gonna be clooosssse. Probably won't rub on the regular, but maybe a little in a sharp turn.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
Quick Reply: Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
