Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Jul 18, 2017 | 03:15 PM
  #7561
saidseven's Avatar
Originally Posted by MaksymV
18x10 +25 on a 2004 g35 sedan fornthe rears?
yes
Old Jul 18, 2017 | 06:06 PM
  #7562
Blue Dream's Avatar
I drove ttrank's car solo
Too simple an answer. Lots involved to get that set up to work.
Old Jul 19, 2017 | 05:59 PM
  #7563
MaksymV's Avatar
could you specify the details on what i nees to get done please
and would 245/40/18 work?
Old Jul 20, 2017 | 07:50 AM
  #7564
Blue Dream's Avatar
Is this a serious question?
Ummmm yeah, we already had this back and forth in your other thread yesterday about the same issue. I suppose reading comprehension>you.......
Old Jul 20, 2017 | 01:01 PM
  #7565
MaksymV's Avatar
thank you for the help.
I ended up buying the rims anyways.
now scratching my head.
Old Jul 20, 2017 | 06:31 PM
  #7566
Blue Dream's Avatar
you go boy...........
Old Jul 20, 2017 | 11:58 PM
  #7567
MK119's Avatar
2004 g35 coupe with Brembo
Stock height, planning to get the following setup:
Niche Targa wheels
Front - 245/35/20 +35 offset rim size 20x8.5
Rear - 275/30/20 +40 offset rim size 20x10
Would I have any issues on rubbing or scrapping?
Thanks in advance
Old Jul 22, 2017 | 07:16 AM
  #7568
Blue Dream's Avatar
No but those wheels will be hella sunken in...........and to most of us look like azz.
Old Jul 28, 2017 | 08:57 AM
  #7569
rvvhimiqbvl's Avatar
Currently bone stock, but I want to get as close to this look as possible (obviously won't be the exact same). Any suggestions as to what size, width, offset, and tire sizes I'd need considering I have brembos? Also how much of a drop? I'd prefer not to have camber. Thanks in advance!
Old Jul 29, 2017 | 08:40 AM
  #7570
Blue Dream's Avatar
You'll never get close to that look w/o some decent camber adjustment. Do you seriously want your rear wheels to stick out as far as the ones in the picture? That car is dropped a LOT, either it's on coilovers that are maxed out or it's on air suspension. To get the wheels, tires, camber and toe adjustable parts, fender work and suspension bits to achieve that look you're probably looking at spending a few thousand dollars. Make sure you budget accordingly so you don't get stuck halfway through the project because of a lack of funds.
This isn't as simple as big wheels and springs and you're good to go.
Old Jul 29, 2017 | 09:46 AM
  #7571
G35freaks's Avatar
20's with some pretty good stretch. Coilovers, aftermarket camber kit, rolled or cut fenders with a possible pull.
Old Jul 30, 2017 | 06:52 PM
  #7572
Also, out of curiosity, what's the most aggressive setup you can run w/o running camber or modifying fenders? For 19s, I read somewhere on this forum that 19x9.5 (let's say 245/35 tires) in the front and 19x10.5 (let's say 275/35 tires) in the rear with +22 all around, but others said you'll be fine up until +12, and I've seen people supposedly running between +12 and +22 without modding and no issues whatsoever according to rimtuck.com. What's the truth here? And what about for 20s? Let's assume a 1" drop all around.
Old Aug 1, 2017 | 07:34 PM
  #7573
SilverSurfer01's Avatar
Hey guys I have a 2006 g35 sedan RWD ,I recently purchased some 350z track wheels v1 , I'm having a hard time making a decision on choosing the right tire size ,I looked up what other people are using 245/40R18 all around I'm leaning towards this choice what are you guys thoughts? thanks
Old Aug 2, 2017 | 06:04 AM
  #7574
Blue Dream's Avatar
245/40 is a great size for those wheels and should work well for you.
Old Aug 2, 2017 | 08:50 AM
  #7575
Thanks for the response ,so running a staggered set isn't necessary at all
What about 245/45/18? Is that better? Sorry I have no clue when it comes to choosing tires ,the rims are 18x8 and rear 18x8.5 but I don't want to run a staggered set
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
