Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
#856
#858
#860
Ok guys I know Im going to get flamed but I need to post here in order to get a more definite answer, because I know the people who lurk this thread know what they're talking about.....
I just ordered some stance coils and going ALOT lower of course w/ kz bumper and ings sides
My question is what size spacers can I run up front and rear without changing tires to be rubbing a little/flush?
Wheel Specs:
20*9.5 et 24 255/30/20 Yoko S-Drives
20*10.5 et 15 275/30/20 Yoko S-Drives
Heres a couple pics as fitment so far: Yes I know ALOT more low...
I was thinking 20mm front and 15mm rear.....Or should I run a 225/35 upfront w/ a 25mm spacer?
Wheel Specs:
#861
do you have any camber kits installed?
it doesn't look like it.
your rear offset and tire size is a perfect size, but since you want hella flush run a 10mm spacer and a lot of camber. Or run a 255 tire and 15/20mm spacer and a lot more camber to get you hellllaaaa flush.
fronts coud get away with a 10mm and little camber, keeping your original tire size. Or run 235/30 tire and 20mm spacer.
in all giving you the strected tire and hella flush.
#862
#864
Questions... I own a 2004 G Coupe. I bought/installed the 08 G37 Akebono BBK - and now I want to go aggressive/flush with 0 or negative offsets... I'm SO not mechanically inclined, logically I think it won't work? The rears should fit easily, but will the fronts need huge spacers, the calipers up front are monsters (am I out of luck for an aggressive setup?). I'd like to do something like some Work VS-XX... Or some Work Gnosis (step-lip) 20's. I LOVE Meisters, but I want 20's. Any advice is helpful (I will be dropping it for fitment on some coils if that makes any difference and doing a minor tire stretch). Last question, is the Work 2D Chrome for the VS-XX too 'blingy' for the G? Thanks in advance
#865
Work Gnosis will lend you a bigger lip in the end, no one has them and cheaper too.....
Work Vs-xx got played out IMO and 2D chrome looks good if setup right
But yea your going to need to do a fender roll definitely in the rear and maybe some upfront, but just dont do what I did and listen to your Vendors and get WEAK offsets. Definitely stretch those tires
Call rick at Ravspec, he'll hook you up good too
pm me if you have any questions
#867
g35 coupe w/ brembo
okay so i'm looking into getting some new wheels and this is what i've got in my shopping cart for the time being:
front : 19x8 35mm
rear : 19x9.5 25mm
what do i need (in regards to spacers) to buy in order to clear the brakes and be close to flush? thanks in advance
also, what tire sizes should i be looking at?
front : 19x8 35mm
rear : 19x9.5 25mm
#869
just checked and should i just go ahead and run 9.5 with 25mm on all four?
#870
I'm looking at replacement wheels after my stockers were stolen right out of my driveway! I have an 04 G35 coupe with Brembos. Has anyone tried out O.Z. Alleggeritas? I know it's a relatively new wheel, but I wanted to check, as Tire Rack doesn't list the 18s as fitting over Brembos. I'm looking at getting the 18 x 8 +35s. Not an aggressive fitment at all.
Thanks muchly.
Thanks muchly.
