Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
#1126
So I'm doing the 20" miro m6 wheels on my 03 coupe with brembos. My question is what tire size could I run? Let me give you some info and specs about what I have.... I have the BC BR coils with camber kits for front and rear. The specs on the wheels are 20x8.5F and 20x9.5R with a 20 offset. So my questions are before I send these off to be drilled for our bolt pattern will these work with brembos AND what tire size should I run with these? Thank you very much for and help you guys give me. Please pm me or reply here!!
However, for the widths, what I would run would be a 225/30 in the front and a 245/30 in the rear. Depending on how low you're going to lower, you'll need a rear fender roll in order to clear.
#1127
These are good sizes. For me tho, I'd probably put a 225/35 in the front instead of a 235/35. You could probably get away with a 245/35 in the rear if you want more of a stretch.
#1133
Depending on what size of tire and how low your drop is, you might rub on the front bumper fender mount when your suspension goes up while you drive. To correct this issue, you either need to take a hammer and make the metal bracket flat or shave it down smooth completely. Or negative camber works too.
#1134
on
Front bumper fender mount?? Is that in the inner fender well? Well I'm in the process of getting everything together. As far as low goes, the car will be on function and form type 2s, and spl camber arms front and rear. Fenders are stock still, and I don't mind having to roll them or maybe a slight pull, but I didn't want to have to a crazy pull and flare. And ya I prollY be going with a nice stretch on the tires. Thanks for all your input guys.
#1135
on
Alright I’m in the process of buying Bags for my 2006 M45. Since I’m running air I’m sure I have some more play room. Can someone point me in the right direction on what specs to get for my rims.
I plan to buy staggered 20’s with max lips, stretched tires maybe 9.5 front 10.5 rear.
I plan to buy the G37 BBK in the near future so I’m assuming I will have to go with O disk in the rear and R disk in the front. I will be pulling my rear fenders a bit. M45 fenders are already rolled.
So what should I go with?
Offsets:
Disk:
tire size:
Your help is greatly appreciated .
Offsets:
Disk:
tire size:
#1136
#1137
Ok guys I have a question? I'm look at getting a set of Webssport wheels for my coupe. The size will be, Front 18x9 +32, Rears 18x10 +32. So my question is will they fit and if so what tire size can I fit. I also plan on lowering car and currently have stock suspension. Thanks for your input
#1139
