Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
  #1321
Old 12-12-2010, 11:39 PM
EMendoza79's Avatar
235 45 18 all around
Will I have problems running 235 45 18 blizzaks all around on my stock 18" rims? Need to be 100% sure before I buy. thanks
  #1322
Old 12-14-2010, 01:51 AM
migelito1's Avatar
Im looking for some kranson forget silvers 20s someone knows where a could get itit
  #1323
Old 12-14-2010, 09:59 AM
racinazn's Avatar
If I were to buy some Konig Lightning's from JLB in 18X8 +45 for all 4 would I need spacers and if so what size to make them sit flush if the wouldn't be all ready...
  #1324
Old 12-14-2010, 10:29 AM
LaserRedG35VS's Avatar
I cant get a straight answer anywhere, someone please help. Im getting some 19x9.5 and 19x10.5 wheels, whats the best offset (in order to give me the deepest lip) I can get? I have BREMBOS.
  #1325
Old 12-14-2010, 05:37 PM
NiNguy's Avatar
I'm getting some Volk GT-F's soon, and was wondering if I will run into issues running 285's rear and 255's front on stock suspension?
wheel sizes are 19 x 9.5+17 front and 19 x 10.5+24 rear
thanks for help or recommendations!
  #1326
Old 12-15-2010, 01:08 PM
Blackedout's Avatar
I picked up 19x9.5 +12 and 19x10.5 +12 rims, I am currently stock height and will be running 245/35 275/35 tires.
Will I need to roll my rear fenders and will these clear Akebono G37 brakes?
I have had terrible luck with toyo t1r tires and I want to get a different brand, any reccomendations?
  #1327
Old 12-15-2010, 04:38 PM
antknee's Avatar
yo!
are nexxens any good for stretching? like 245/35 on a 10.5, i know some brands can handle it i was just wondering if nexxen's can.
  #1328
Old 12-19-2010, 02:42 PM
teahead's Avatar
Hey doods, noob here.
I'm wanting to put 295-30-20s on the back. Not going for the stretch look. Anyone run this tire on a 20x10?
Offset is +25 for the wheel I'm lookin' at (Axis Pentagon). I'm thinking should be no problem with minimal fender roll?
Car is fairly low with Tein coilovers (maybe 1.5" lower than OEM).
Thanks.
  #1329
Old 12-19-2010, 02:45 PM
SkylineGTR2789's Avatar
Thanks.
295 seems a little wide, it might bubble over a little at the recommended psi .. i think 275 would be right
  #1330
Old 12-19-2010, 02:57 PM
teahead's Avatar
Well...I'm not wanting ANY spacers.
Since a 295 is only 10mm wider on each side than a 275, it's the equivalent almost of putting on a 10mm spacer.
Which should give it a flush look, while all the same having more rubber on the road for traction (think...performance) and more comfort with a slightly thicker sidewall to avoid pending a rim in pothole Seattle.
  #1331
Old 12-19-2010, 03:03 PM
well since you're lowered , you may have to roll your fenders with those sizes
  #1332
Old 12-19-2010, 11:13 PM
Gevo1's Avatar
What tires are good for stretching? Moderate stretching?
  #1333
Old 12-22-2010, 05:51 PM
99probs's Avatar
hello g35driver. 1st post is a prob.
can anyone school me on the fit of these 18" stock infiniti wheels?
http://images.craigslist.org/3n03k23...38265f1f91.jpg
its raining like crazy in CA and I need a set that will clear the brembo kit on the coupe (03-06) like, today.
the seller has this info but cannot confirm if they will clear:
pattern 5x114.3. offset 45
if they will clear I will buy, if not- If anyone has a set of wheels/tires for sale LMK!
thanks in advance for your any responses i may receive
  #1334
Old 12-22-2010, 06:21 PM
trentor's Avatar
They are from the sedan 6MT/sport. They will be 0.6" closer to the calipers. That seems like quite a bit, so I can't imagine they would clear. That offset would also would look horrible on the coupe. It doesn't look the greatest on the sedan either.
  #1335
Old 12-22-2010, 06:41 PM
99probs's Avatar
Trentor- thank you for that information, I truly appreciate it. and so the search continues.. all the best to you & yours.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
Quick Reply: Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
