Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Dec 28, 2010 | 08:36 PM
  #1351
pdl3thm's Avatar
air pressure
19" rays low profile tires always seem to need air. . . ? Is this a common thing? I've had the car since june... 2006 g35 19" rims. . . Looking for info about it.. . . Thanks
Old Dec 30, 2010 | 02:58 AM
  #1352
inda626's Avatar
Tire size for 19x9, 19x10??
Hey how's it going? Been trying to search for some info, but haven't had any luck for the info I'm looking for. A lot of the info that comes up is based on 9.5, and 10.5's.. Would appreciate it if anyone can help out. I just got some wheels 19x9+21, and 19x10+20, and am wondering what tires sizes I should run on them? What I have seen so far is a lot of people running 245/35 & 275/35, but am wondering what are my other options without throwing off the VDC? Dropped on Tein CS, camber kits front and rear, with rear fenders rolled by Shane. Any help would be appreciated. Thanks
Old Dec 30, 2010 | 03:22 AM
  #1353
JBF's Avatar
JBF
check valvestems
you can still run those sizes and be fine
Old Dec 30, 2010 | 03:40 AM
  #1354
inda626's Avatar
Thanks for the quick reply
What would be some other options? Or would you suggest I just roll with those sizes as stated before? 245&275.. Or should I go with something with more rubber, since Los Angeles is full of pot holes? Any suggestions? Appreciate it! Thanks
Old Dec 30, 2010 | 07:31 PM
  #1355
stealthlude00's Avatar
Hello everyone. I wanted to get Rota P45Rs on my G. I spoke to Rota and all they have available in 19s are a 19x10 +20 for both front and rear. Would it be acceptable, as far as looks go, and wat tire size should I be running in the front? And would i be able to get the same tire size all around to finally do some tire rotations? lol Thanks!
btw, i have the BC Coils, and have a rear camber kit, but need the front. I am dropped a lil over 1.25".
Old Dec 31, 2010 | 01:03 AM
  #1356
jdm_dudebro's Avatar
Removed
Last edited by jdm_dudebro; Jan 1, 2011 at 01:32 PM. Reason: Moved my info to Wheels section.
Old Dec 31, 2010 | 01:19 AM
  #1357
VEN0M's Avatar
I find it interesting. Out of 15 or so questions on this thread. 2 get answered. And ive asked my question twice already with no responses.
Old Jan 4, 2011 | 01:47 PM
  #1358
InfinitGman's Avatar
A question to all Work VS-XX owners
Hi all,
I'm looking to purchase a set of VS-XX's and all the other suspension components for my setup in the late spring/summer time. Right now I'm just getting some research in before I start throwing money around.
I'm looking at the sizing charts for the 19 inch VS-XX's and I see that there are three different disks; A-Disk, O-Disk, R-Disk. What exactly are the differences between the three? And, how does that affect the fitment of wheels with the sizes of F: 19x9.5 +22 R: 19x12 +20?
*Those offsets are just a guess I feel that might have been best, but I'll change later with more research.
Thanks for all your help, and I'll be posting up some more when I have some more questions.
Old Jan 4, 2011 | 07:46 PM
  #1359
mkvl127's Avatar
i have a 05 sedan..and want 18x8.5 in the front and 18x9.5 out back..whats a good offset to get that will be aggressive but will be functional since ts my daily driver..i what a little poke out back.. i was thinking +20 all around?. and i should be lowered on coilovers by the time the rims are purchased and i want to run a 265 rear and 235 front
Old Jan 4, 2011 | 08:12 PM
  #1360
CandlestickPark's Avatar
ill Sedan
+15 up front and +20 out back will be nice, flush and very functional. You'll have to dial in negative camber and roll your fenders flat in the rear.
Here was my setup when I had smaller spacers, larger tires and wasn't as low as I am now, dropped 2.5" inches on BC Racing coilovers
8.5 +15, 245/35
9.5+ +20, 255/35
Here are a bunch of pics static and rolling so you get an idea of what it will look like.
Old Jan 4, 2011 | 11:43 PM
  #1361
mkvl127's Avatar
^^ i think id have to run a 265/40/18 in the rear and 235/45/18 up front so that if i get a flat i can use my spare tire without throwing off the awd..if i did get a flat and the tire sizes were different would it mess up my awd if i only drove like 10miles? id rather run a smaller sidewall like a 265/35/18 and a 235/40/18
Old Jan 5, 2011 | 12:35 AM
  #1362
ill Sedan
^I just realized you said 18s vs 19s. Unless you are going to be slammed 3"+ I wouldn't do 18s, they'll look too small IMO.
Old Jan 5, 2011 | 11:46 AM
  #1363
mkvl127's Avatar
i wanted to do 19s but the tire selection isnt any good and tires alone were like 450$ more vs getting 18 inch tires..im 19 paying for school..i read somewhere that 19s made the X sluggish also..
Old Jan 6, 2011 | 03:00 PM
  #1364
vinco's Avatar
Ssr gt3
I am looking at a set of SSR GT3's for my 6MT coupe with Brembos. Specs are 18x8.5, +30 offset. Will these clear Brembos without spacers? I'm unable to test fit them, due to location.
Old Jan 7, 2011 | 06:08 PM
  #1365
Pepper's Avatar
18x8.5? Damn near stock. Stock is 18x8 +30 up front. Look for a set of OEM 19's. Youre much better off.
They should clear the brakes just fine.
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
