Have a Question/s About Wheels/Tires/Offsets/Camber/Etc? Ask here::
Rating: Thread Rating: 3 votes, 3.67 average.
Old Nov 11, 2010 | 10:48 PM
  #1291
DourG35's Avatar
Hey my friend just gave me his wheels that came off his car. I was wondering can i fit a:
Front = 8.5' wide...40+ offset. Front tire is 245/35/20
Rear = 10' wide...40+ offset. Rear tire is 275/30/20
Also I know I prob need spacers, so what should i run in the front and rear ?
Can i run this on coupe with brembos ?
Old Nov 12, 2010 | 08:07 AM
  #1292
reverse's Avatar
yes, those would work. your gonna need spacers with those high offsets. i would at least say 20mm all around without knowing if your lower'd or not.
Old Nov 13, 2010 | 08:13 PM
  #1293
bnorris85's Avatar
Have an 03 6speed with Brembos
Looking for winter set up
Sport Edition A7 Silver Painted
Offset: +32mm
Backspacing: 5.59"
Bolt Pattern: 5-114
225/55R17 and 225/50/R17 Bridgestone Blizzak WS70
OK?
Thanks
Old Nov 23, 2010 | 09:25 PM
  #1294
jdescha4's Avatar
Does anybody know what wheels these are?? What size are they??
I am looking for something similar so I'll take any suggestions.
Thanks
http://www.google.com/imgres?imgurl=...w=1007&bih=508
Old Nov 24, 2010 | 03:22 AM
  #1295
K.ste2's Avatar
Hopefully someone can give me an answer.
I have 20x9.5 front and 20x11 rears. Putting on 225/35/20 and 255/35/20.
My car is currently lowered on Tanabe springs. The question is, will I need to roll/pull my fenders? Or should I be OK, since I'm not slammed.
Old Nov 24, 2010 | 03:35 AM
  #1296
Nightcrawler's Avatar
^^ depends on your offset and camber. Do you have adjustable camber arms?
Old Nov 24, 2010 | 04:02 AM
  #1297
K.ste2's Avatar
No, everything is stock except the springs. I don't have the offset exactly, I think like +11 front and +18 rear. I know I got a setup so I can run BBK. I figured I don't need cambers cuz I'm not low at all.
Old Nov 24, 2010 | 04:07 AM
  #1298
K.ste2's Avatar
I'm just wondering if I'll be able to drive it out the shop without rolling my fenders until I get my coilover and camber setup. Until then I didn't sangho worry about rolling/pulling the fender. Cuz the car will be in the garage til summer.
Old Nov 24, 2010 | 04:09 AM
  #1299
K.ste2's Avatar
** didn't want to worry **
Sorry for the spelling, I'm on my iPhone.
Old Nov 25, 2010 | 08:43 PM
  #1300
zmeansgo's Avatar
couple of questions. The car being spoken of is a 2006 g35, 19in wheel sport package(spoiler gives it away right?)
1) The bolt pattern is 5x114.3 right? so wheels with a 5x130 won't fit would they?
Reason being I can't find anywhere that sells 19x10.5 axis penta's in a 5x114.3 pattern
2) with everything else stock do you think this setup would rub
Front: 19x9.5 +22 255/35zr/19
Rear: 19x10.5 +22 285/35zr/19
3) If so, what about:
front: 19x8.5 +22 245/35
rear: 19x9.5 +22 275/35
4) If you think both of those will rub what would you suggest? Also, if I am correct about the 5x130 bolt pattern not fitting, does anyone know of a place I could buy them in the correct pattern?
Old Nov 28, 2010 | 02:32 PM
  #1301
Kenny_Cox's Avatar
New guy here! shopping for some wheels right now. There are the 19" wheels on the car right now, but I might want to switch them up to a different style. Just looking around right now. i am an ebay shopper, just for styles, will source the wheels elsewhere. But, I found these "concept one" wheels. They look pretty cool, price seems about right.
They are:
19x8.5 +38mm
It says 5x4.5 is the same as 5x114.3 so it'll fit that way, what about the offset?
They are also available in 19x9.5 for staggered, but they have the same offset. Seem about right? Seems iffy to me but wanted to ask!
Old Dec 2, 2010 | 01:53 AM
  #1302
JBF's Avatar
JBF
so lets say I want to run O disk w/OEM bbk...
how big of a spacer will I need?
I know it will clear the rear caliper...but how much to clear the front?
Old Dec 2, 2010 | 02:02 AM
  #1303
dukehotty's Avatar
Originally Posted by coreydee
i've got the wheels on...
everyones saying i'll probably need spacers now in the front...
Whatever those wheels are made of... is the same material your ***** are made of!
Old Dec 2, 2010 | 02:04 AM
  #1304
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
Someone told me you'd need to run a 25mm to clear O disc.
Old Dec 2, 2010 | 02:12 AM
  #1305
JBF's Avatar
JBF
really? I didnt think it was that much...
hmmmmm
You have already rated this thread Rating: Thread Rating: 3 votes, 3.67 average.
