yes, another offset question.
Just wondering what size spacers would i have to run to get good fitment/poke. Specs are Volk SF Winning 19x9.5 +29 front 19x10.5 +29 rear. Also, would the rear springmount mod work to lower it more? I'm pretty much almost maxed out on the Tein Basics in the rears. Actually in these pics it's not maxed out but I don't have any current pics. Thanks.
if you are looking for more aggressive, without having to run negative camber, stretched tires, etc, i would say 15mm spacers all around. you'll likely need to roll your fenders. and yes, the springmount mod can drop you lower with coilovers
Because the Tein basic are not a true coil over in the rear so it uses the springmount still..
I would go 25mm spacers all around and then do the spring mount, roll the fender paper flat, and dial in camber as nessecary.
Next time just ask it in here
https://g35driver.com/forums/wheels-...-ask-here.html
But 25mm front and rear
