Question for New wheels on Lowered G
Old 05-28-2009, 12:23 AM
j 4 lD's Avatar
Originally Posted by eurodre
oh really? 9.5 -14 can get you about a 4 inch lip and 10.5 -8 gives you about 5 or so
point being, doesn't have to be wide *** wheels
10.5 isn't wide? That's wider than most guys roll with, no? I see your point tho. My point is that the lower the offset, the closer you get to a bottom limit for how narrow your wheels can be.
Old 05-28-2009, 12:25 AM
eurodre's Avatar
naww 10.5 is not too bad, from what i've seen it's a pretty common choice
but you can get away with a huge lip, nice clearance on a 9.5 , the lip is not AS big but you can get a max lip of like 4 inches with its pretty good for most people
Old 05-28-2009, 01:43 AM
Triple8Sol's Avatar
Originally Posted by j 4 lD
Just as a reference, here is a picture of what offset actually is, for those who don't know. Negative offset would require wide *** wheels with a deep dish look (huge lip).
Obviously there are varying degrees of offset, but this diagram gives you an idea of how it works. I know many people that know exactly the perfect offsets for their car, nice fitment, etc, but have no idea what offset actually is.
Funny, because you fall into that category yourself, evidenced by your statement that negative offsets require wide wheels.
Old 05-28-2009, 03:20 AM
Sylvan lake V35's Avatar
To be "flush" for the AVERAGE GUY is 19x9.5 with +18 offset and 19x10.5 +17 offset those are average flushness with normal camber and requiring a rear fender roll. Alot of guys go with lower offsets and wider wheels and lots of negative camber...but thats extream most guys that posted in your thread fit that catagory and you need to know what you are doing (or your wheel guy) to an extent if if you are ordering your custom sizes and offset.
Old 05-28-2009, 03:36 AM
ShanesG's Avatar
J 4 lD please stop posting!
Op,Like sylvan said you gotta know what you want. The offsets and sizes he gave are pretty common for "flush" fitment running the right spec tires and camber.
Those sizes 9.5" +18, 10.5 +17, are the same as an 8.5" +6, 9.5" +5.
Old 05-28-2009, 10:37 AM
eurodre's Avatar
+1 on the right camber, with 25mm spacers on my stockies in the back (19x8.5) and im at an effective offset of 8 but my camber is keeping me from being flush
Old 05-28-2009, 02:09 PM
only1waqas's Avatar
I guess theres more to offset then one can think...
Old 05-28-2009, 02:39 PM
ShanesG's Avatar
^Not really.
Offset is offset. The measure + or - from dead center of the wheel. Thats all it is.
It's when you're choosing different widths when people get confused.
But there are other things to consider other than offset when searching for a perfect fitting wheel.
rezendvous420
05-31-2020 01:26 PM
G35Sask
Intake & Exhaust
16
08-05-2015 10:17 PM
kinetek
08-03-2015 04:25 PM
IEMaestro
20 Inch
07-30-2015 04:30 PM
Detailed Image
07-24-2015 12:31 PM
Quick Reply: Question for New wheels on Lowered G
