What tire size to run
Old Jun 26, 2009 | 11:47 AM
cubanato's Avatar
I have a set of staggered 19's from my ex 2002 maxima.
I have and 05 G35x
If I remember correctly they are;
19x9.5 and 19x10.5
current tire set up;
front 245/35ZR19
Back 275/30ZR19
What is the best tire set up to run for this to work on my AWD car , if it does work?
Old Jun 26, 2009 | 01:03 PM
Swivel's Avatar
Moderator
No expert here, but wouldn't the offsets be completely unsuitable given that they come from a FWD car?
Old Jun 26, 2009 | 01:28 PM
Canadian's Avatar
Canada, eh?
I don't know anything about the offsets, but you should run at least 275 on the front and a 295 in the rear. I have that setup on 9.5 x 9.5 track wheels. Don't go small!
Old Jun 26, 2009 | 01:53 PM
Jeff92se's Avatar
Red Card Crew
Good luck running those sizes on a 05 G35X.
Old Jun 26, 2009 | 06:18 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
Yeah, they seem a bit short for an awd. Typically see the same size all around on an X to avoid trans case issues. On the rwd a 245/40 f and 275/35 r.
Old Jun 28, 2009 | 03:40 PM
cubanato's Avatar
Can i run the same size tire on both wheels? or is it too much of a width difference?
Old Jun 28, 2009 | 03:46 PM
Frankieg35's Avatar
245/35/19 and 275/35/19
Old Jun 29, 2009 | 08:09 AM
cubanato's Avatar
So I can run this setup as long as they are both at 35 width?
Old Jun 29, 2009 | 11:11 PM
Chico's Avatar
that set up is way too tall for our sedans and doesn't look very good. I've had 245/35/19 front and 275/30/19 for years without any issues whatsoever. It is the most popular set up on sedans.
OP, if you have the X, you should consider getting same size wheels and tires all around. Otherwise you will have some issues with your AWD system.
You can run 18x8.5 +30 to +35 offset with 235/45/18 or 245/40/18 all around. Or 19x8.5 with 245/35/19 or even 245/40/19 if you want the extra cushion and don't mind the fat looking tire on your wheels.
Old Jul 3, 2009 | 09:04 AM
Fusco's Avatar
How about 255/35/20 on a sedan will this work???
Old Jul 3, 2009 | 04:03 PM
PLATINUM SPONSOR
A little tall/wide than normal but have seen others use it.
vitamin.v
Nov 7, 2019 06:10 PM
Jnm07
Aug 6, 2015 03:03 AM
reaper76
Aug 5, 2015 10:13 AM
Popes
Jul 29, 2015 05:07 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
