toyo t1r asymmetrical?
Old Aug 4, 2009 | 05:48 PM
HXS's Avatar
HXS
i got toyo t1r's and they say "left" and "right" on the sidewall.
can i swap them side to side?
why did they put that designation on the sidewall?
Old Aug 4, 2009 | 05:50 PM
zackt69's Avatar
rarejdm.com
The treads have to face a certain way... so for example, if you put a tire on the left wheel and the word "right" is facing out, then the treads are rotating backwards. Flip the tire over and mount it on the wheel the other way and the word "left" will be facing out.
Old Aug 4, 2009 | 09:23 PM
HXS's Avatar
HXS
^ yeah right now, they're all facing the right way.
but i wanna swap them side to side to save them from camber wear and so word "right" will be on left and "left" will be on right.
is that ok?
Old Aug 5, 2009 | 02:58 AM
zackt69's Avatar
rarejdm.com
No, you can't rotate directional tires without taking them off the rims and swapping them. The word "left" should always be facing out on the left, and the same for the word "right" on the right side of the car. The tread pattern will be rotating in the wrong direction otherwise.
jilljann1
Jul 21, 2020 08:12 AM
tkuntz
20 Inch
21
Sep 26, 2016 09:13 AM
Britishbloke
Jan 27, 2004 11:42 AM
