Extremely loud humming noise from tires!!!
not to bust anyone's bubble on this thread, but the only reason ur get this "humming" noise is not because of struts or springs or tire size or anything even close in that area, but because of tire/rubber softness, thats it, simple as that.
-the harder the rubber the more noise and slower wear down
-the softer the rubber the less noise the faster wear down
-temp plays a lot too
there are MANY diffrent tires out there in softness rubber so do ur resurch be fore you buy!
thats it good luck
thats it good luck
thats it good luck
thats it good luck
Correct. However, camber really has nothing to do with this. It's toe. Ways to combat this wear and noise problem.
1) Don't run directional tires
2) Set toe to maximum toe-in (0.16" total)
3) Cross-rotate the front tires every 2000 to 3000miles.
4) Wider tires and rims make the problem worse
My G has the same problem and doing these 4 fixes has happened the address the problem significantly.
Bridgestone RE760... not exactly the cheapest but they aren't that much more than Direzzas, FK452, etc... and you get much more quiet and comfort from them. Next one down on my list would be Direzzas, and that's as cheap as I would go... I don't feel Falkens or Nittos are worth the money at all on a dd.
The compound of the tire plays a small role in the tire noise. The noise comes from the air that goes THRU the tread grooves. so if you want a quiet tire buy a tire with smaller tread grooves and more sipes.
Tires are acoustically tuned [the tread depth andblock size and shape] to cancel some of the road noise as tires wear to half tread most of the special tuning is GONE.
Depending on the price you pay tires start getting noisey at 5k > 15-20k miles.
Usually ultra premium Michelins are the quitest for a given tread wear.
ScraggleRock
Aug 11, 2015 10:16 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
