Coupe rims with 04 Z suspension?
Old Aug 8, 2004 | 06:40 PM
Renesis's Avatar
Anyone know if I will rub if I use coupe rims with 2004.5 Z suspension??
I want to lower the car after getting the coupe rims but not sure if they will rub. Thinking if I should get the Z suspension or get some lowering springs like Tein S-tech, H&R or Eibach.
Someone help?
Old Aug 8, 2004 | 06:52 PM
av8r's Avatar
Re: Coupe rims with 04 Z suspension?
It is about 1 inch all around. Check out gsedan35 ride in this thread. Also there is more good info on this thread so read the whole thing. Hope this helps.
https://g35driver.com/forums/showfla...sed&sb=5&part=
2004 Sedan 6MT Silver/Graphite/Premium/Aero/HuperOptik/XM
Z-Tube/Stillen Airbox/Grounding Kit
Stillen sways OTW/ 2004 350z suspension OTW
19x8.5/9.5 Axis Hiro OTW
Toyo T1S 245/40 275/35 OTW
Old Aug 8, 2004 | 07:28 PM
Renesis's Avatar
Does that mean it will not rub???
Old Aug 8, 2004 | 09:15 PM
av8r's Avatar
I dont think it will. I think, in your case, rubbing is more a result of the wheels not the suspension. The 350z suspension is a mild drop. If anything, lowering brings the top of the wheel in a little which may help to keep them from rubbing the fender. The coupe wheel offsets are less than the sedan so, if they rub, it will be the edge of the tire against the outside edge of the fender not the suspension. Do a search for some people with coupe wheels and shoot them a pm. Sorry I cant be of more help as I do not have coupe wheels. Check out this link and pm jedmonds and lilmauwow.
Old Aug 8, 2004 | 10:11 PM
Renesis's Avatar
Actually I am sorry that I didnt post all the information.
I actually got a 2003.5 G35 sedan and I just got a set of coupe wheels and I am just wondering if it will rub if I put a set of 2004.5 Z suspension on my car.
Old Aug 9, 2004 | 04:36 PM
Renesis's Avatar
Old Aug 9, 2004 | 04:40 PM
dklau33's Avatar
Don't worry, you'll be fine.
04' G35S 6MT Ivory Pearl, Willow, Premium
Z-Tube / NFC Y-Pipe / Custom Mid-Pipe / 350 EVO Rear Sway/ '03 350Z Shocks and Springs
Old Aug 10, 2004 | 03:14 AM
Gsedan35's Avatar
Wouldn't it be soooooooooooooooo much easier if Infiniti gave the sedan the same offset's as the coupe and Z and the same fender clearances.
I dunno, low offset's on the sedan don't alway's mix. One thing that doesn't help matters is that most all the coupe fitment's I've seen on the sedan are not lowered. One member did lower his sedan on Eibachs, which lower at least a little bit more then the Z suspension does (some times definately more). BUT, did that one member correct his camber? That really matters because less negitive camber moves the tires closer to the fender lips. Of course if you plan on a performance alignment anyhow, that's a mute point.
Any time I see the Z suspension mentioned, and possibly using lowering springs only, I'll remind you that the Z suspension will be much superior performance wise, it's about shock control(weight transfer control) and linear springs vs progressive. In the same breath, it's about what you want out of the car when your done.
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Old Aug 10, 2004 | 03:23 AM
Renesis's Avatar
Well, I managed to find someone who is willing to sell me his 2004.5 Z suspension over at my350z forum but he crashed his car somehow and said he wouldnt get it back for at least a month so I will just have to wait and see if I got the deal.
I know many people did the swap to Z suspension and loved it and I also love the coupe rims too so I really wanna know if I should get the Z suspension after the coupe rims. Since I have the non-sport suspension, I think using lowering springs would not help my car much.
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
jjohns2711
Aug 5, 2015 08:58 AM
BlackGee35
Jul 23, 2015 01:36 PM
