17s Front, 18s Rear
Old Oct 2, 2009 | 12:39 AM
Turbonegro's Avatar
17s Front, 18s Rear
I know that the 17in stock 7 spokes will fit over a OEM Brembo setup, but has anyone run the 17in. stock 7 spokes in the front and 18in. stock 7 spokes in the rear?
The reason I ask is because I have dented too many rims in the front to this point and would like a slightly beefier tire. Since the 17s look the same as the 18s, but have a thicker tire, would this work?
Any problems that you might think I will have by doing this?
Old Oct 2, 2009 | 12:42 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
the stock coupe 17's are 6 spoke...
-GP-
Old Oct 2, 2009 | 12:57 AM
Turbonegro's Avatar
-GP-
I know which one you are talking about, but to my knowledge, there is a 17x7 7 spoke wheel that looks exactly like the stock 18.
Old Oct 2, 2009 | 01:03 AM
which is made for the sedan and has a high offset which will look like crap on a coupe. And i HIGHLY doubt it would clear stock Brembo brakes.
Why not get a fatter tire up front on your 18's? You can run a 225/50 or a 245/45 up front and do a 255/45 in the rear.
-GP-
Old Oct 2, 2009 | 11:36 AM
Turbonegro's Avatar
-GP-
I wouldn't get rub from a 245/45 up front?
Do you think I can run the 245/45s on all fours until I can get the 255/45s in the rear without issue?
Old Oct 2, 2009 | 12:17 PM
nghiars's Avatar
1. If you are on stock suspension or just mildly dropped, you WILL NOT rub.
2. Yes.
Old Oct 2, 2009 | 02:22 PM
Turbonegro's Avatar
2. Yes.
Good to know. Thanks!
Old Oct 2, 2009 | 09:34 PM
You can be dropped down to the floor and you wont rub with 245/45's all around. I've put the same setup on a coupe lowered slightly with Tein H-Techs and another coupe with espiler springs which is a good 1.8" drop.
-GP-
Old Oct 2, 2009 | 10:35 PM
FlyingLumpia's Avatar
Umm turbonegro gdup knows what he is talking about. Trust me I bugged him enough that what advice he gave to me worked.
rezendvous420
May 31, 2020 01:26 PM
bu villain
19 Inch
Nov 15, 2015 09:23 PM
TheKnite
Aug 14, 2015 07:59 PM
st33zygill
Jul 29, 2015 10:05 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
