S-Tech any problems ?
Old Aug 10, 2004 | 06:27 PM
DJames's Avatar
I want to lower my car but i do not want to buy a camber kit so i wanted to know for the people with Tein S-tech did you guys buy camber kits or did you guys get it almost to stock status ?? if you didnt buy a camber kit are you guys going to by one later or you think it is okay with a little negative on the tires please help me thanks
Old Aug 11, 2004 | 04:25 AM
DJames's Avatar
Re: S-Tech any problems ?
Bump .... anyone ?
Old Aug 11, 2004 | 05:00 PM
Gfly's Avatar
I only got an alignment, and they said it was close to even. I don't plan on adding a camber kit. I'll just see how long the tires last.
Old Aug 11, 2004 | 05:02 PM
SilverG35C's Avatar
I have had my S.Tech's on for over 10 months now and haven't really had any problems with tire wear. At least nothing that drives me insane
Jason
Got a Coupe?
Old Aug 11, 2004 | 06:19 PM
DJames's Avatar
so everything is going good for you guys ?? the tires are somewhat wearing out evenly ??
Old Aug 11, 2004 | 06:37 PM
GG35's Avatar
u will probably have problems. these guys are saying, nothing "too bad". what does that mean?you could probably lose a lot of life out of your tires due to the uneven tire wear. its a risk, but its up to you if u want to take it.
Old Aug 11, 2004 | 07:34 PM
DJames's Avatar
what gives a better drop the Tanabe GF(for 350z) or the Tein S-Tech and anyone that has either spring installed can anyone answer to GG35 comment ? true ?
Old Aug 12, 2004 | 05:45 AM
G2FAST's Avatar
I have the Tein S-tech and I love them, I like the way the car sits and drives and looks. Got my Tein's at Street Image in SoCal and they did a great job. The only item you will need to buy will be sway bars to take them corners faster.
My 2004 G35
Old Aug 12, 2004 | 10:57 AM
GG35's Avatar
i'm lowered on h techs . 6 front and .3 rear and i have some major negative camber already for some reason. I dont know how it will affect my tires yet though.
Old Aug 12, 2004 | 11:54 AM
DJames's Avatar
the tein's drop at 1.2 F and .9 R and the Tanabe drop at 1"F and 1.2"R which one should i go for ??
Old Aug 12, 2004 | 06:10 PM
Gsedan35's Avatar
I don't know which Tanabe's your looking at, heres the spring rate specs for both so you can see how they differ from the Teins. Biggest thing that stands out is how the Tein's use a lot less rear spring stiffness, something that will add understeer. The call for adding on sway bars is thus even more justified then usual.
Tanabe NF210 Springs G35 COUPE
297/336 F-5% R-2%
Transfers +3% roll stiffness to front
Tanabe DF210 Springs G35 COUPE
308/353 F-2% R+3%
Tein H-tech G35 coupe & sedan(fronts are progressive, rears are linear)
324/260 F+ 5% R-22%
Transfers +27% roll stiffness to front
Tein S-tech G35 coupe & sedan (fronts are progressive, rears are linear)
358/274 R+14% R-18%
Transfers +32% roll stiffness to front
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
bananax
Sep 24, 2019 12:24 PM
G35xdriver04
Nov 7, 2015 08:31 PM
itgogitrev
Sep 23, 2015 07:08 PM
mattdg35
Sep 14, 2015 11:28 AM
