Will I have to roll my rear fenders?
Old Oct 6, 2009 | 08:37 PM
mmmk's Avatar
20" Work Varianza T1S
Front:
20"x9.5" with +15mm offset
245/35/20
R-disk
Rear:
20"x11" with +25mm offset
275/30/20
O-disk
My G35 is lowered on 350z Tein S-Techs and I have the OEM Brembo brakes. My camber kit has the rear camber set at about -1.6 degrees.
My questions are:
1) Will these wheels clear my BBK?
2) Will I need to roll my rear fenders?
Thanks in advance!
Old Oct 6, 2009 | 09:03 PM
EL-EE-ES's Avatar
1. yes they are the correct disk to clear brembos
2. you should be fine with the +25 with out rolling
Old Oct 7, 2009 | 02:38 AM
mmmk's Avatar
Thanks
Also, would you happen to know if the Varianza's require hub centric rings to fit perfectly on the G?
Old Oct 7, 2009 | 02:56 AM
Skaterbasist's Avatar
Retired SuperMod
You should be fine.
Now, if you lowered more with less than 2 degrees negative camber, then maybe.
Old Oct 7, 2009 | 02:59 AM
mmmk's Avatar
Thanks!
I'm putting them on tomorrow (for like a month before the rain arrives here in Vancouver), hopefully I have no issues.
Old Oct 14, 2009 | 08:09 PM
Neu Era's Avatar
your brakes will be cleared. Unfortunately you'd have to roll your fenders.
Old Oct 14, 2009 | 08:13 PM
Locksmith's Avatar
You should be gravy I'd roll the fenders just in case but I think you'll be ok.
Old Oct 14, 2009 | 08:15 PM
mmmk's Avatar
I don't get any rubbing when driving around with 3 people. I haven't tried driving around with a full car load yet. Hopefully there isn't any rubbing. I'm taking off the wheels soon (so much rain in Vancouver nowadays) and prepping for the winter.
I'll decide if I need to roll my fenders next summer...as of now, I'm just happy =)
obender66
18 Inch
Mar 13, 2016 12:20 PM
helalo
Aug 10, 2015 08:21 AM
Tylerttn
Aug 10, 2015 07:13 AM
st33zygill
Jul 29, 2015 10:05 PM
Soumilg
Jul 18, 2015 12:33 PM
