Tire size question
Old Oct 23, 2009 | 11:01 AM
DEEZBLUBALLZ's Avatar
Tire size question
I bought the following, now just need tires for it. Everyone recommends 245/35/19 and 275/35/19 in rear. I am probably going to run Nitto Neo Gen, or Nitto Invo.
Question is can i run wider tires in the rear? like a 285/35/19?
Wheels are the following:
MSR 089 19x8.5 +24
MSR 089 19x10 +40
Just don't want to rub, or roll anything quite yet. These are temporary wheels.
Old Oct 23, 2009 | 11:10 AM
Deezflip's Avatar
Yes, you can run 285/35/19 with the 245/35 in the front.
but...the MSR 089 19x10 +40 is a pretty bad offset. I'm not completely sure but you might rub in the inner part of the wheel well, or rub with a suspension part with 285 and +40 offset.
Old Oct 23, 2009 | 12:16 PM
Is it going to stick in too far and look ridicoulous? What kind of spacer do I need? I haven't test fitted the wheels yet, due to me needing tires still.
Old Oct 23, 2009 | 01:33 PM
nghiars's Avatar
for a 10 in rim... your'll probably need at least a 20mm spacer. maybe a 25 mm spacer depending on how flush u want your rim to your fender or if you want to deal with rollng your fender.
Old Oct 23, 2009 | 08:48 PM
Is it going to stick in more than the OEM wheels? I have the 19" ones. If so I definetly will need spacers! Thanks for the advise....
vitamin.v
Nov 7, 2019 06:10 PM
Jnm07
Aug 6, 2015 03:03 AM
reaper76
Aug 5, 2015 10:13 AM
Popes
Jul 29, 2015 05:07 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
