Is there anyway to fix wheel offset? Just put coupe wheels on my sedan...
Old Nov 17, 2009 | 04:39 PM
  #46
Jeff92se's Avatar
Red Card Crew
You can flip tires right -> left IF the tire tread allows it. ie.. directional but symmetrical. Or Asymmetrical but not directional.
Old Nov 17, 2009 | 05:03 PM
  #47
Swivel's Avatar
Moderator
Originally Posted by ShanesG
lol yeah, only theres nothing to add, doesn't really leave himself with many options.
Lower More
Increase camber
Smaller tire
Basically all he can do is run a smaller tire since he doesn't want to do either of the other 2.
True enough, okay, you're off the hook, LOL! He's on the right track now, anyway.
Originally Posted by donpisto
Not the way I'm talking about flipping it. You would do it side to side, which is what I'm doing for my car. I have 235/35's in the rear and 225/35's up front.
You take the tire from the left side and put it on the wheel on the right side and the tire on the left side and put it on the rim on the right side.
What you are describing is rotating the entire wheels and tires. I'm talking about leaving the rims in place and just swapping the tires side to side.
Dismounting/remounting like this is effectively putting the inside of the tire on the outside of the car on both sides (if ya follow me) so that the more wear-prone area (the inside) can be moved to the outside and even things out.
Old Nov 20, 2009 | 04:13 PM
  #48
canucklehead's Avatar
the oem 225/40 and 245/40 sizes are working well for me. OP - i recommend these, and i am lowered on Z springs FYI.
rezendvous420
May 31, 2020 01:26 PM
Brodys_GCoupe
Nov 7, 2015 08:06 PM
Soumilg
Jul 18, 2015 12:33 PM
Jadenkid22
Jul 14, 2015 12:33 AM
