Tire Size Suggestions...
Old Nov 21, 2009 | 09:17 PM
Matzo Ball's Avatar
Red face Tire Size Suggestions...
Just swap my stock wheels on my X for coupe 18s. Since the tires are staggerred, I need to get rid of 2 tires. Dont want to buy 4 new for the time being.
Fronts: 225/45/18
Rears: 245/45/18
What would you do? Go all 245/45 or all 225/45? Other suggestions?
For reference, I will be dropping the car over the next few months on Tein H-Techs or H/R Sedan springs.
Old Nov 21, 2009 | 09:24 PM
str3zz's Avatar
Fronts: 225/45/18
Rears: 245/45/18
make it all 245/45 ... the bigger the tires the better for driving and turning and much more stable and of course look a lot better.
Old Nov 22, 2009 | 01:43 AM
6MTFTW's Avatar
245/40/18 all around.
Old Nov 22, 2009 | 08:33 AM
jimmyc13's Avatar
You might want to run some calcs to see which is closest to OEM outer diameter specs. Sorry, but I don't have calc. near me, otherwise I'd do it for you.
I'm running slightly larger than OEM size when it comes to outer diameter (245/40/19), so if anything, you'll want to run the larger size, otherwise you'll have a more significant fender gap and your speedo will be off a bit (mine is off by 2% or so).
Old Nov 22, 2009 | 11:57 AM
5150DS's Avatar
Stock sedan sport is 235/45/18. Look here to compare sizes: http://www.1010tires.com/tiresizecalculator.asp
I would go with the 245.
Old Nov 23, 2009 | 11:22 PM
Morovasa's Avatar
I agree with 245 but you may want to compare and do the calc as suggested above.
You will thank us later
Old Nov 24, 2009 | 11:34 AM
Matzo Ball's Avatar
Going w/ 245/45's Thanks all.
Old Nov 24, 2009 | 12:48 PM
Morovasa's Avatar
Good Decision.. Let us know what you decide and how it comes out afterwards
Old Nov 24, 2009 | 01:54 PM
Matzo Ball's Avatar
If I drop it, will I have rubbing issues with the 245/45s?
Old Nov 24, 2009 | 02:21 PM
nghiars's Avatar
^^^yes and no depending upon your drop... You should drop it first unless you really need tires.
Old Nov 24, 2009 | 02:30 PM
PAIXAO's Avatar
I'm dropped on Z/Coupe springs and I rub in the rear with 245/40 when going over some bumps. If I ever have my GFs daughter (~50lbs) in the back seat it rubs more.
Could probably be taken care of with a little negative camber.
Old Nov 25, 2009 | 09:31 AM
Matzo Ball's Avatar
hmmm, with the rubbing, looks like no drop for me on the x.
Old Nov 25, 2009 | 01:04 PM
Jeff92se's Avatar
Red Card Crew
What tires are they? My Micheline pilot sports in the 255 width is almost if not more narrow than the RE050s in the 245 width.
Old Nov 25, 2009 | 01:07 PM
TurTLe*'s Avatar
i ran 265/40 michelin PS2 and they were rubbing but that was almost a given
Old Nov 25, 2009 | 04:00 PM
Matzo Ball's Avatar
Riken Raptor 245/45/18s
