Getting 20" rims but need to figure tire size
Mar 3, 2010 | 02:05 AM
even though the tire width is roughly the same, you're pushing the wheel 13mm closer to the fender with a +17 offset versus your current +30. you'll be even closer to the fender if your new rim width is wider than your current wheel.
like others have mentioned, you'll probably be fine with a +17 offset and 275/285 tire. its not that aggressive of a setup. however, you can build in some more room by either rolling your fenders or running more camber.
Reply 0
Mar 3, 2010 | 02:08 AM
yeah, there's a big difference between +30 and +17.
don't forget 285/30 won't be as stretched as 275/35 so there's more chance of rubbing.
Reply 0
Mar 3, 2010 | 10:56 AM
crap, I never knew the offset pushes the wheels closer to the fenders... i always thought the smaller the offsets, the more concave the spokes are to the rotors.
Reply 0
Jun 11, 2010 | 10:37 PM
I thought the front fenders come pre-rolled from the factory? So how do you roll the front fenders?
Reply 0
Jun 12, 2010 | 11:04 PM
I'm gonna say you will rub pretty badly with 275 given your 10.5" and 17mm offset. I'm dropped 1.5" and run 285 with 10" and 25mm offset and I rub, however you can put some really (-) camber to make them fit but I would roll first. BTW offset numbers changes depending on the rim's width. Your 10.5" +17mm compared to my 10" +25mm sticks 14mm out more than mine not just 8mm.
Reply 0
