who's running 19" on there sedan?
Mar 10, 2010 | 04:06 AM
Having 35front offset and 45rear offset. It's not a good choice? Can somebody explain what the offset measures? I'm very confused. Thanks
Reply 0
Mar 10, 2010 | 06:54 AM
running 19 x 8.5 (+42) with a 5mm spacer making it a +37 offset
Tires are 245/40/19.
I suspect you will rub if you drop and hence need a good camber kit.
Reply 0
Mar 10, 2010 | 07:47 AM
I wouldn't stagger your tires with AWD
Reply 0
Mar 10, 2010 | 10:16 AM
Quote: Having 35front offset and 45rear offset. It's not a good choice? Can somebody explain what the offset measures? I'm very confused. Thanks
each +1 in offset = 1mm of center. the higher offset, the closer the wheel is towards the inner suspension. As you get lower and towards - offesets, your wheel is closer to the edge if not past your fender line.
Quote: I wouldn't stagger your tires with AWD
You can, but be VERY carefull of rolling diameter.
Reply 0
Mar 10, 2010 | 02:18 PM
Here's what NOT to do:
https://g35driver.com/forums/media-s...r-fenders.html
Reply 0
Mar 11, 2010 | 01:51 PM
Quote: I hope I can find a reasonably priced set once I get back from Afghanistan...
Dude be careful out there , I hear the speedbumps out there r huge
Reply 0
Mar 12, 2010 | 12:17 AM
19x8 25mm with 235/35/19 in the front and
19x9.5 40mm offset with 255/35/19 rear. I love how the wheels fit (rear flush and front is almost flush)....rear rubs a little with rear passenger(s). I need to roll the rear fenders. This pic is before the 15mm front spacer.
Reply 0
Mar 12, 2010 | 04:22 AM
If the wheel looks weird with 35 front and 40 rear offset, can I fix this problem with spacers?
4D05G35> do u have an awd sedan? What U lowered?
Reply 0
Mar 12, 2010 | 11:51 AM
You can move the wheels out with spacers if they are tucked in too far.
Reply 0
Mar 12, 2010 | 12:01 PM
Running 19's here
19x8.5
19x9.5
Eibach pro-kit
Rolled fenders cuz they used to rub.
Reply 0
Mar 12, 2010 | 12:09 PM
i have the same offset; running 245 35 in front and 265 30 in the rear. dropped on KW coilovers. it's not an aggressive offset; you won't need to roll the fenders, unless you slam it. i have about a finger clearance in the rear w/ no rubbing issues.
Reply 0
Mar 12, 2010 | 05:48 PM
Forgot to mention I am running G/Z combo.
Reply 0
