20mm/25mm or 25mm/30mm spacers with OEM 19's
Old May 4, 2010 | 01:15 PM
  #31
ke104's Avatar
This is the best i could find while i'm at work. Maybe I'll go outside and take a pic if I have time.
Old May 5, 2010 | 10:30 AM
  #32
Tyoung's Avatar
Just recently put the ichiba v2s on my 06 coupe with 25 up front and 30 rear install was super easy...sits perfectly flush and i love how it looks...rolled my rear fenders and real excited to put the pro kit on it in a week or two...the 1/1.1 inch drop should be perfect...id say go with 25/30!
Old May 31, 2010 | 04:33 PM
  #33
L23Tan's Avatar
I'm running Ichiba Version 2 Spacers - 20mm F and 25mm R.
Tires: 245/35/19 Fronts and 245/40/19 Rears on OEM 19's.
Car is dropped 1.0" in the Front.
Camber: -1.03 Driver and -1.10 Passenger
Car is dropped 0.6" in the Rear.
Camber: -2.03 Driver and -1.89 Passenger
I have slight rubbing on the Rear Right when the car goes over dips or imperfections on the road that makes the suspension compress more than normal driving on a completely flat and smooth road.
I'm still a little confused why the Driver Side Rear visibly has more clearance than the Passenger Side Rear. Anyone else experience this?!?!
Old May 31, 2010 | 09:57 PM
  #34
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
Hey OP, your set up looks great. If you ever wanted to go lower, you could always cut your spring mounts.
Anyways, here is my set up. I'm running 15mm front and 25mm rear. After looking at your set up, I should have ran 20mm in the front.
Just temporary for now, until my wheels come in sometime in June.
P5290022.jpg?t=1275274246
P5290023.jpg?t=1275274392
Old Jun 1, 2010 | 12:38 AM
  #35
L23Tan's Avatar
Originally Posted by ke104
update. Ichiba V2 20mm front, 25mm rear, with OEM 19's 245/35/19 front, 255/35/19 rear. Dropped on JIC Magic FLT Coilovers almost all the way. Damper settings 10 front, 8 rear. SPL front arms/rear camber arms. Have about 1/2" wheel gap on all 4 wheels, no rubbing, no rolled fenders. This is absolutely as low as you could go without any clearance issues or rolling the fenders. Off to Roger Krauss for minor adjustments and corner balance next week.
Nice set up!
What are your alignment specs?!
Old Jun 2, 2010 | 11:40 PM
  #36
herrschaft's Avatar
So I installed my spacers last week. (20/25mm) I torqued everything to 80lbs, but I think one of the studs is stripped because the lug continuously spins at around 50lbs. Has anyone experienced something like this with the Ichiba V2's?
Old Jun 3, 2010 | 08:01 PM
  #37
vietboi817's Avatar
I'm at stock height and I don't plan on dropping nor getting my fender rolled. I plan to get 245/35/19 F and 275/35/19 R. Is it possible to run 25mm in the back?
Old Oct 7, 2010 | 05:52 PM
  #38
adam infinity's Avatar
i know this thread is a few months old but im thinking of doing 25 all around and im running 245F and 275R and was wondering would the rear be rubbing or not??
Old Mar 30, 2011 | 05:16 PM
  #39
HATEM87's Avatar
guys i have a Q, am running 235/50/17x7.5 rear and 225/50/17x7.5 front... would it be ok if i put 30mm spacers all around?
Old Mar 30, 2011 | 05:17 PM
  #40
HATEM87's Avatar
BTW, the car looks good!!
Old May 3, 2011 | 03:01 PM
  #41
Manny2ksi's Avatar
what would be a good recommendation on spacers for a Tein H drop with stock 19's.
dont plan on rolling the fender. just want a slighlty more aggressive.
would 20/15 be fine or should i go with 15/10?
thanks!!
Old May 3, 2011 | 08:54 PM
  #42
Xet's Avatar
Xet
thanks!!
I ran that setup with 25mm all around and it looked great and no rubbing. You might be able to fit a 30 in the rear even without rolling. But when I bumped up the tire size a notch I ended up rubbing.
Old May 5, 2011 | 08:30 AM
  #43
Manny2ksi's Avatar
okay so ill do the 20 f / 25 r
Old Sep 11, 2011 | 09:16 PM
  #44
_FrankStarks_'s Avatar
Older thread but you guys got pics?
Old Sep 12, 2011 | 02:57 PM
  #45
bryan_tberry's Avatar
Here's some pics of my car with 20/25's. Stock suspension, no springmount mod or anything.
Edit: pic fail
Attached Thumbnails 20mm/25mm or 25mm/30mm spacers with OEM 19's-2011-09-03-18.41.37.jpg   20mm/25mm or 25mm/30mm spacers with OEM 19's-2011-09-03-18.41.56.jpg   20mm/25mm or 25mm/30mm spacers with OEM 19's-2011-09-03-18.43.27.jpg
