20mm/25mm or 25mm/30mm spacers with OEM 19's
Old Sep 12, 2011 | 03:01 PM
  #46
_FrankStarks_'s Avatar
Damn that looks good. Who makes those spacers?
Old Sep 12, 2011 | 03:22 PM
  #47
bryan_tberry's Avatar
A number of vendors. Ichiba makes the most name brand of them, but I got mine from a member on the board. You can get them on ebay too, just make sure and get hubcentric. either way you slice it they are slabs of metal that go behind your wheel, so in my honest opinion, one isnt any better or worse than the other ones. Just get them tight on there, make sure you go hubcentric, and you'll be fine.
Old Sep 12, 2011 | 05:12 PM
  #48
Cool. Any plans to lower?
Old Sep 14, 2011 | 11:43 AM
  #49
sum spicy rice's Avatar
Originally Posted by bryan_tberry
Here's some pics of my car with 20/25's. Stock suspension, no springmount mod or anything.
Edit: pic fail
wow that looks good. any side shots of the car. just curious if the wheel gap looks worse/better using spacers on stock suspension
Old Sep 14, 2011 | 07:08 PM
  #50
Wheel gap looks a little better honestly, but its still pretty apparent. It doesn't look as stuffed in and under the car, but you'll definitely be itching for a drop. I'll try and get a side shot up by Saturday.
Old Sep 27, 2012 | 06:32 PM
  #51
Gisele's Avatar
Hey guys I have OEM 19 wheels. What size spacers can I put in front and rear without rolling the fenders?
Old Oct 9, 2012 | 02:44 AM
  #52
dj714's Avatar
What about on a stock suspension with 20" rims should I roll with 20mm F and 25mm R or 15mm F and 20mm R ?
Old Oct 9, 2012 | 12:22 PM
  #53
hcag2's Avatar
^ you prob need to post your current offsets...
Old Oct 9, 2012 | 01:12 PM
  #54
dj714's Avatar
Lol. How could I figure that out? Traded for this car about two months ago and it came with the rims. Seems like they don't have an offset both front an back used the same tire and lips looks to be the same size
Old Oct 9, 2012 | 03:34 PM
  #55
VMRWheels's Avatar
The wheel dimensions should all be listed on the back side of the wheel (in most cases).
Needless to say, I would just measure to find which spacer would fit your needs the best. You don't exactly need the offset for that.
Old Oct 9, 2012 | 04:47 PM
  #56
dj714's Avatar
Will do today after work.
Old Oct 9, 2012 | 05:04 PM
  #57
VMRWheels's Avatar
Sounds good!
Old Oct 13, 2012 | 12:04 PM
  #58
nogoodname's Avatar
Here's a pic with 30mm spacers all around.
Tire and camber spec: 235/35 (-3°) and 245/40 (-3.2°).
Old Mar 4, 2013 | 06:19 AM
  #59
JerSoPhresh's Avatar
Currently running Tanabe DF210 and Tokico hp blues, I'm sitting pretty low. Stock OEM19's with stock tire size. Not looking to roll fenders. Would 20mmF/25mmR work ok without any problems with rubbing?
Old Mar 7, 2013 | 06:07 AM
  #60
Bump before I buy 20f 25r on lowered TanabeDF210. Will I have any rubbing issues with how low I sit? Going to be sitting on stock camber adjustment settings. Not looking to rub
