Tire size help.
Old Mar 28, 2010 | 08:15 AM
Borna's Avatar
Tire size help.
Hey guys, I'm getting new tires because my current 255/30/20's are causing me to scrape the mid-section of my exhaust. The reason why this is happening is cause I have 245/35/20's on the front wheels which are 26.75" in diameter whereas the rears are currently at 26.02".
I'm gonna be putting 255/35/20's in the rear which will be 27.02" in diameter, so a 1" difference. From what I've been told, this should fix the scraping issue.
Now I'm thinking of going from 245/35/20 in the front to 235/35/20 but that'll mean the front tires will be 0.28" smaller in diameter so I'm worried it'll cause more scraping.
The reason I want to go for the 235/35's is to match the stretch on the rears.
Wheels are 20x9.5 +25 up front and 20x10.5 +33 and I'm dropped on H&R springs. 2nd gen sedan.
Anyone know whether I'll have any problems or will I be ok with this change?
Old Mar 29, 2010 | 03:33 AM
Borna's Avatar
Anyone? I gotta order the tires soon so I need help ASAP.
Old Apr 3, 2010 | 03:50 AM
ckp's Avatar
ckp
going for the 235/35 up front wont that lower it more causing more scrapping like you said?
Old Apr 3, 2010 | 04:37 AM
Borna's Avatar
Yeah it will lower it but unlike the 245/30/20 that you're running (which is 1" smaller in diameter), the 235/35/20 I ordered is only 0.28" smaller in diameter.
That means it will lower the car by around 0.15" or so. That is such a minimal drop that it won't cause any scraping.
I posted this thread before doing any calculations. Plus I spoke with both Grant and Levon and they said it shouldn't have any effect.
Old Apr 6, 2010 | 05:16 PM
neal@tirerack's Avatar
PLATINUM SPONSOR
I'd go with the 245/35's. Better overall diameter and carries closer to the correct amount of weight.
Old Apr 6, 2010 | 06:08 PM
Borna's Avatar
Thanks for your reply Neal, I've already ordered a set of 235/35/20 and 255/35/20 General Exclaim UHPs from tirerack. I'm just waiting for you guys to get the rears in stock so they are shipped out.
I went with the 235/35's to clear my fender bracket and match the stretch that the 255/35's will give in the rear. The maximum load for the 235/35's is 1389 lbs which means it is more than enough to safely put on the G anyways.
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
paolojericho11
Sep 11, 2015 07:08 AM
Jnm07
Aug 6, 2015 03:03 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
