Gonna run 19"/20" S5:F, tire size?
Old May 13, 2010 | 10:26 PM
NachoCheese's Avatar
So when I get my new credit card in a few weeks, I'm gonna by some Five Axis S5:Fs. And then I got to thinking while looking at other sexy concave wheels on an NSX forum, why don't I run 19x9.5 or 9.5 in front, and 20x10.5 in the rear? I did some searching, and there's really no problems. My question is, will my tires work? They're 35 series sidewalls... do I need to get 30s for the rear so my VDC doesn't go nuts? Or does the VDC eventually get used to it eventually? I want there to be a good distinction between the bigger rear and smaller front, and I'm afraid the 30s in the rear will make them look the same height. If there's no way around this, I'm just gonna get 19s.
Old May 14, 2010 | 02:10 AM
apro06g35's Avatar
Basically the rule you need to keep in mind is that you need to keep your OD (overall diameter) within 3% +/- of your stock OD. If you can manage to do that, not matter what size wheels/tires your running, your VDC will be ok.
I am running that wheel in 20x9.5 and 20x10.5 & I love my current setup.
Great wheel, but a little on the heavy side.
Look for a tire size calculator online.
Old May 14, 2010 | 07:19 AM
How concave is your rear? Could you take a head on pic at a slight angle for me? I want that widest one in the rear. And thanks for the advice, I'll do that after I come home from work
Old May 14, 2010 | 07:40 AM
I'm probably gonna run 245/35-19 up front and 265/30-20 in the rear. They're both just under and just over 2%, so that should be good for my VDC
Old May 14, 2010 | 08:53 AM
MEXTEP's Avatar
I beleive Randy is running 20 and 21..ask him.
Old May 14, 2010 | 06:30 PM
apro06g35's Avatar
yeah ill see if I can find a pic later on dude, its not Extremely concave but the 10.5 is def. more than the 9.5
vitamin.v
Nov 7, 2019 06:10 PM
Jnm07
Aug 6, 2015 03:03 AM
reaper76
Aug 5, 2015 10:13 AM
Popes
Jul 29, 2015 05:07 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
