View Poll Results: So what size wheel ? ? ?
19"
13
52.00%
20"
12
48.00%
Voters: 25. You may not vote on this poll
Work Varianza T1S - Should I get 19" or 20"
Old May 14, 2010 | 10:54 AM
liche's Avatar
Okay, so i've decided on the Varianza T1S rims (probably lightning silver as that matches my car's trim the best), but now am up in the air between 19" or 20" wheels.
Both wheels are going to fit, and i'll be rolling the fender in either case, but just not sure which way i should go.
I guess the arguments are show vs. performance, but do i really care about performance from a smaller wheel with lower inertial mass? Probably not.
Anyways, what are your thoughts ? ? ? ?
Old May 14, 2010 | 11:00 AM
Frankieg35's Avatar
20's!!! Ftw!!
Old May 14, 2010 | 11:55 AM
Mr_pharmD's Avatar
the 20s arent that much heavier compare to the 19" like 5 lbs more. Just take out the spare and u are good to run 20", lol.
Old May 14, 2010 | 11:58 AM
ConradoR's Avatar
seems like u answered your own question. If you don't care about performance, just go with 20s.
Old May 14, 2010 | 12:04 PM
GR6RR's Avatar
20s step lip!! with agressive offsets!!!
Old May 14, 2010 | 09:53 PM
G 30-FI's Avatar
CLUB MODERATOR
^ i 2nd that man!!! 20's step lip all the way!!
Old May 14, 2010 | 11:42 PM
jibberjabbers's Avatar
20" tire are cheaper than 19's.
But with 19's. It's a bit street friendly because you get to slap on thicker tires.
Old May 14, 2010 | 11:44 PM
YeloFva's Avatar
Twin-Tays
Old May 14, 2010 | 11:47 PM
erklep's Avatar
if you are truley concerned with performance, t1s are not that right wheel for you anyway. so with that being said, go 20s for cosmetics. like stated above, aggressive offsets and step lip!
Old May 16, 2010 | 06:55 PM
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
Looks wise, definitely go 20's!
JibberJabber's is right, 19" tires will cost more then 20" tires. I got my T1S in 20's and I haven't regretted it one bit.
Old May 16, 2010 | 09:32 PM
whoozyadaddy7's Avatar
20's just step all over 19's as far as looks are concerned.... These rims are legit, I'm sure you wouldn't be disappointed. +1 again on the tires, saving 100$ on every set of 4 adds up!
Old May 16, 2010 | 09:37 PM
iiiiiekoiiiii's Avatar
dude u make 416rwhp 19s to 20s should be ur last worry. Thats if u track ur g35 on N/a engine...
always 20s on g35 coupe, like everyone already knows with steplips and aggressive offsets.
No need for crazy stretched tires in ur case, Cause u wanna be able to put the power down with some tire. but like 10.5 rear with 275 should be fine. Or come to the darkside, and run 305s
Old May 17, 2010 | 06:58 PM
petesg35's Avatar
19s look just as good as 20s.
Old May 17, 2010 | 07:10 PM
GR6RR's Avatar
as mentioned above...
20s Step LIP FTW!!! 20x10 20x11 !!!
Old May 17, 2010 | 09:37 PM
I'm just wishing someone would put some of these up for sale......
arora_g35
Apr 16, 2026 02:52 PM
obender66
18 Inch
Mar 13, 2016 12:20 PM
Big C
19 Inch
11
Oct 3, 2015 05:11 AM
JMSABO
Aug 4, 2015 11:58 AM
attarday
Jul 15, 2015 04:03 PM
