possible to have even camber in rear with this setup
Old May 23, 2010 | 07:57 PM
nyckid's Avatar
I am trying to do my research but need some assistance. I plan to lower my car pretty low on stance coilovers. The wheel specs are 20x9.5 and 20x10.5 +5 all around. Tires are 225/35/20 and 245/35/20. I am trying to avoid having excessive negative camber, especially in the rear. My rear fenders are rolled. Is it possible to have my wheels in the rear to have almost positive camber. I do not like the excessive negative camber look and am trying to avoid it as much as possible.
I am running SPC rear camber kit with toe bolts in the rear.
Old May 24, 2010 | 11:07 AM
soundmike's Avatar
K, just a wild guess here as i'm not too familiar with the 1st gen but for a moderate drop your SPC should be able to bring the rears back to spec.
Old May 24, 2010 | 01:18 PM
Xet's Avatar
Xet
^the problem he would most likely run into I would guess is that there is literally no space to get it back to spec, but I'm not expert with how far you can pull a fender/how much room you can get out of it. Also it really depends on how low he is planning on going.
Old May 24, 2010 | 03:36 PM
nyckid's Avatar
i plan on slamming the car when i get my coilovers. So i'm guessing 2.5" or more. I want to dial in as much positive camber as I can.
Old May 25, 2010 | 12:16 PM
SuperStezzyG's Avatar
well heres a car with 20x9.5, 20x10.5 +5 all around with 225/35 and 255/35 lowered on tanabe DF210 camber front -2.5 and rear -3.0 with the fenders rolled flat.
http://www.rimtuck.com/setup.php?id=611
this should give you a idea of how you can play with you camber..
Old May 30, 2010 | 10:49 AM
solobaric's Avatar
With a 2.5" drop or more in the rear, we can't even get close to -1 deg camber let alone 0 deg utilizing the SPC kit. The camber arm will allow for it, but the toe setup is the limiting factor.
As I see it, the only way is to figure out how to add toe adjustment by replacing the radius arm with an adjustable one or losing the spring bucket for an arm with more adjustment.
I know this because I've run into the same issue with only about a 2.25" drop.
The best my alignment guy can do is right about -2.0 deg camber (with proper toe)
In reality, going more positive than about -1.5 to -2.0 deg is actually going to decrease our handling. But for aesthetic purposes, I understand the look. Let us know how it turns out for you.
Old Jun 1, 2010 | 01:36 AM
nyckid's Avatar
thanks guys, will let you know when i get them. i just want to have as much positive camber as possible with being slammed. i really dont like the excessive negative camber look at all.
Old Jun 1, 2010 | 01:51 AM
Skaterbasist's Avatar
Retired SuperMod
What do you mean almost positive camber? Why would you want that? Even being at or close to zero is not ideal in any situation.
If you mean you prefer to have it within manufacture specs, I would say no seeing that you have the wrong tire profile series for 20" wheels. You could probably get it in the -1.7 to -2.2 range since you stretch tires though.
For reference, I have 19x9.5 +7 and 19x10.5 +3 on 245/35 and 275/35 tires with -2.8/-2.7 camber. My fenders are rolled pretty flat. I don't rub in any situation except when I'm angling in and out of driveways or when I have more than 2 passengers in the car. My drop is just enough to where I don't have any wheel gap.
Your front shouldn't be an issue. Your rears might be.
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
beevanhuynh
Jul 23, 2015 01:37 AM
nascarbuff17
Jul 16, 2015 10:23 AM
