Spacers
Spacers
So I can't seem to find a straight answer. If spacers are installed correctly are they safe to drive on?
I have 25mm spacers for the front and 35mm spacers for the rear and I'm waiting to get them installed until I know if they are completely safe or not. If torqued in correctly and everything is installed right, are they safe to run?
Thanks for the help.
I saw a G that had spacers on it to where the wheels were flush againest the body, didn't get to ask him what size they were. My car is not lower, nor do I plan to. What size would be the way to go for a 2005 G35 Coupe, with factory Forged 19" wheels. Please share your thoughts? Thank you!
on
when i had my 19's at stock height I ran ichiba V2 size 20mm in the front and 25mm in the rear and loved it... i thought it was just about perfect but some people go bigger. just make sure to torque em down, mine started "walking" or loosening after the second week ~ once torqued down, I never had another problem
I would recommend going with at least 25mm all around. If you don't plan on dropping your car very much I would even say 25mm front/30mm on the rear looks absolutely amazing. There was someone running that setup and if you search around I'm sure you can find his pics.
there is a search feature on the forum. you cna also search via google by entering what youre searching for and then enter "g35driver.com"
