Need Rim HELP, BAD!!
Old Oct 5, 2004 | 10:36 AM
avs007's Avatar
Re: Need Rim HELP, BAD!!
The stock front rims are +30mm offset. I heard +35 will still work on the front. (Just don't go any higher than +38)... It depends if you have brembos, cause if you do, then I don't think +35/+38 will clear them.
But if you are going through the trouble of getting the rims custom made, you should be going the other way offset wise... I got my 18x8.5 in a +25mm offset.
EasySausage
Sep 24, 2015 01:06 PM
NJ6MT
Sep 10, 2015 08:40 AM
n2fooz
Sep 4, 2015 07:46 PM
TheBay
Sep 3, 2015 03:27 PM
