will this tire setup raise my car up?
Old Jun 30, 2010 | 11:35 AM
nyckid's Avatar
I am running factory 18's with the michelin pilot tires (225/45/18 and 245/45/18) now. I plan on upgrading to yokohama s-drive 225/35/20 and 245/35/20 (running stretched). Will this setup have the same overall diameter as my old setup with the OEM 18's since I am stretching the tire?
Old Jun 30, 2010 | 11:39 AM
CandlestickPark's Avatar
ill Sedan
Your new tires will be .2 inches taller in the front and .1 inches taller in the rear compared to your current tires. So you will be a tad higher than your current setup.
Old Jun 30, 2010 | 11:45 AM
nyckid's Avatar
Thanks a lot. That's not a big difference then. I guess if I wasn't stretching than it would be close to half an inch higher.
Old Jun 30, 2010 | 11:58 AM
ill Sedan
^For sure. When you go from 18s to 20s it usually raises the car up some.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
mjfenix
Aug 17, 2017 05:49 AM
itschuckster
Jul 25, 2015 08:07 AM
Karnicle
Jul 23, 2015 05:08 AM
realtalk21
Jul 20, 2015 09:07 AM
