Advice on tire size plz
Old Sep 21, 2010 | 08:56 PM
fcruzer's Avatar
hi peeps,
I'm keen on getting a set of wheels, specs are
19*9.5 +15
19*10.5 0
what's the widest tires that I can put on them without having to worry about rubbing?? also, with the zero offset rears, would i need any major body work or can I get away with rolling the fenders??
I'm currently sitting about 1.7 inch lower front and rear.
cheers
Old Sep 21, 2010 | 11:39 PM
driver1712's Avatar
you probably can get away with rolling/pulling rear fenders and dialing in some camber.
you're pretty low so you can get away with 275/30 widest in the rear i'd say.
Old Sep 22, 2010 | 08:13 AM
idrive_MD's Avatar
275/30/19 is pretty short in the rear, I'd at least do a 275/35 considering the amount of stretching he'll have. I dunno, I could be wrong, I am anti-stretching so my advice might be a little off.
Old Sep 22, 2010 | 11:41 PM
driver1712's Avatar
^ he'll rub with 35 series and +0 offset... unless he's cambered.
Old Sep 23, 2010 | 05:03 AM
fcruzer's Avatar
was thinking more 255/35 19 stretched on a 10.5?? what do u guys reckon ...is this too much stretch??
also worried that the wheels will poke out too much on a 10.5 0 offset....but i know that some guys here run negative offsets on 11 inches
vitamin.v
Nov 7, 2019 06:10 PM
Footballmania32
19 Inch
Jun 2, 2018 07:31 AM
paolojericho11
Sep 11, 2015 07:08 AM
Jnm07
Aug 6, 2015 03:03 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
