225/55 instead of 225/50/17? Ok?
Old Oct 22, 2004 | 05:29 PM
3point5SE_Auto's Avatar
Re: 225/55 instead of 225/50/17? Ok?
225/55 will not rub on a sedan front or rear. they fit great. However you will notice the difference front to rear..
If I were to put those on a coupe I would put the 225/50 or 225/45. It willl look funky on a coupe but it will work fine.
Better Life thru Chemistry
Black on Black 03.5 Sedan 6MT - Goodyear F1 GS-D3's 225/55/17, Custom Intake Tube, '03 "Z" Suspension, Magnaflow resonator, 6 Wire 4 Guage Grounding Kit
Old Oct 23, 2004 | 02:23 AM
moe's Avatar
moe
Good advice guys, thx. If u have em on the sedan, I guess the coupe will be ok too. Maybe the coupe will have less slat to the nose with fatter tires.
03 Coupe(****/blk)K40,NAV,limotint
Me at Infiniti Dealer-"I'm doubleparked in my Gc,I need some brochures." As I walk out, they ask if I bought my car there. I respond, "I tried to, unfortunately!!"
Old Nov 22, 2004 | 03:30 AM
moe's Avatar
moe
This is for front tires which are hard to find. Will this small sidewall difference be a big problem?
Old Nov 22, 2004 | 09:48 AM
TINMAN's Avatar
i'm more concern about the outside diameter.
225/50 is 27.86" and 225/55 is 28.74".almost an inch bigger.
may have rubbing issue.
cdaudis4
Sep 18, 2004 10:19 PM
Renesis
Feb 4, 2004 10:41 PM
