Are 225/55/17's ok for Sedan?
Old Oct 22, 2004 | 05:24 PM
g4ian's Avatar
Considering buying 225/55/17's for winter set up. Is this ok clearance wise?
Thanks,
g4ian
Old Oct 22, 2004 | 05:32 PM
3point5SE_Auto's Avatar
Re: Are 225/55/17's ok for Sedan?
yes I run these for my summer tires. 225/55/17 goodyear GS-D3's (6ply). they fit fine all the way around. if you are using your good rims I honestly would look for some 16" steelies and 205/60/16 tires. I think snows in that size plus steel wheels run about 380 bucks.
or you can get some cheap aluminum mags. In most places teh salt and stuff will eat your wheel's finish.
Better Life thru Chemistry
Black on Black 03.5 Sedan 6MT - Goodyear F1 GS-D3's 225/55/17, Custom Intake Tube, '03 "Z" Suspension, Magnaflow resonator, 6 Wire 4 Guage Grounding Kit
Old Oct 25, 2004 | 02:11 AM
ryoken's Avatar
Works just fine. You can go 235/50R17, too. However, for winter tires, narrower is better.
Old Oct 26, 2004 | 10:28 PM
moe's Avatar
moe
I am trying to figure out the wheel widths for the 17s. The rears use 235s, and fronts use 225s, so they have to be a bit wider in the rear?
03 Coupe(****/blk)K40,NAV,limotint
Me at Infiniti Dealer-"I'm doubleparked in my Gc,I need some brochures." As I walk out, they ask if I bought my car there. I respond, "I tried to, unfortunately!!"
Old Oct 28, 2004 | 03:53 PM
on the SEDAN, all four are 17x7 and you can run 235's on a 7 inch rim
as far as the coupe? I dunno
Jusseth
Sep 13, 2020 12:25 PM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
TheKnite
Aug 14, 2015 07:59 PM
chinee
Aug 8, 2015 10:11 AM
teamghost
Jul 28, 2015 04:52 PM
